Question about Toshiba W522 VHS VCR
Remote problem My remote only works for play, stop, rev and ff. My grandson was pushing buttons on the remote, but I have tried everything and can't get it to work. can you help?
    Sergeant:
  • 291 Answers
Look carefully at the buttons and see if one of the rubber buttons is slightly pressed in, ever so slightly!!! look ever so carefully to see of the OUTER rim of the rubber button is off the plastic rim of the R\C [ remote control] usually PUSHED IN at the RIM ot the rubber button. That causes a short and confuses the r.c in two diferent directions.
Posted on Nov 12, 2008
Remote control for Cyberhome CH-DVD 300 is lost.
they are stop, eject, play ,ff, rr, pause, and power.
Jul 15, 2010 | Cyberhome CH-DVD 300 DVD Player
Wanted steps to unlock region code for Samsung DVD-C370
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player).
  • FF = fast forward, FR = fast rewind.
  • Region 2 players: FF, FR, FF, UP, DOWN
  • Region 3 players: FF, PLAY, FR, UP, LEFT
  • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
  • Region 5 players: FF, UP, DOWN, STOP, RIGHT
  • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen.
  • The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Jun 03, 2010 | Samsung Televison & Video
Remote control intermittent. remote power on button slow and tedious. volume works ok, but channel up and down does not work at all. to change channels mus use numberics. play, stop, ff rev works okay....
take apart the remote and remove the rubber button pad.look at the back of the buttons,the carbon has worn off or got full of oil.take a q tip with alcohol and clean the buttons.if they are worn off,take a small piece of aluminum foil and glue it to the button .it is small 1/8 inch diameter or so.if you look at the pc board,you will see 2 sets of lines for each button that do not touch.looks like a small maze.what happens when you touch the button is that the carbon connects the 2 lines.eventually alot of force is needed to make contact work,but it completely wears out the button contact pad surface.Gluing a piece of foil to the button will make it work.i have done it a hundred times on remotes with no replacement...
cheers ed
Jul 13, 2009 | Emerson EWC1902 19 in. TV/VCR Combo
Citizen c479dvd player will not eject disk says ''Key Lock On'' We have tried everything but we can't turn off the player or eject the disk. We can FF or Rev and switch to other songs but we are stuck with...
Hey.. I was having exact same problem, and couldnt find answer anywhere online, so i actually called citizen.
SO>>> hopeuflly u have ur remote.
Push setup.. then push 00083 then enter.. and there ya go.. problem fixed. YAY>.
If u dont have remote.. not too sure. but heres there number.
18006635954
Mar 17, 2009 | Televison & Video
Need Comcast Remote Code for Samsung DVD-V1000
I just programmed my comcast remote for my Samsung v1000, My comcast remote is very similar to the 3-in-1, but has a few more buttons on it (on the Comcast site, my remote looks like the DVR 3 remote, but I don't have a DVR). The code I used was 21044.
By using this code, the play/stop/rewind/ff buttons all work. I didn't test the record button. The Info button worked as "Display" and Exit button to work as Audio Source (HiFi/Mono). However, the Volume and Channel controls did not work.
I hope this helps.
Feb 19, 2009 | Samsung DVD-V1000 DVD Player/VCR
I have a Sylvania NB501SL9 blu ray player with no remote. i have dish remote and programmed it for the blu ray , the play ,stop and ff/rew. works fine, but i can't get the arrows to work, therefore i cant...
went ont and plunked down 14$ for a new universal remote. could not get the dish remote to do anything other than stop ,play,ff and rew. which just isnt good enough if you want to browse the blu-ray disk @ all !! so gud luk to all. and Merry Christmas !!!
Dec 01, 2008 | Sylvania NB501SL9 Blu-Ray Player
Play/pause/stop/ff/rev/rec not working..
have you tried unplugging the tv for 1 minute and then seeing if it will reset itself. everytime I have had an issue that is the first thing the tech tells me to do. can you call your provider and ask tech for help.
Oct 03, 2017 | Philips PM-DVR8 Remote Control
Toshiba W522 VHS VCR Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
