Question about Video Cameras
Sony CCD-FX310 I was just given this camcorder from my parents since they no longer use it. When I power it up, I can playback but the minute I try to record, it just shuts off like I have no battery connected to it. I tried to run it with the power supply adapter and with a good battery and still the same thing. It will only turn back on if I disconnect the battery or power supply and put it back in playback mode. I was told to replace the small coin like battery, which I did, but still the same issue. The camcorder has very little use and it would be a shame to get rid of it. If it is not a big deal to repair I would like to do so. Thanks for any help.
  • szokejohn2 Nov 30, 2008
    i have the same problem,just shuts off when recording
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Video Cameras Master
  • 575 Answers
Likelihood is that it has reached the end of its useable life.
Posted on Apr 09, 2017
  • 5,412 Answers
AS this camcorder was first produced in 1992,and has lain unused for some considerable period, the likelihood is that it has reached the end of its useable life.
Posted on Apr 05, 2017
philipp
  • 217 Answers
SOURCE: cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Posted on Sep 15, 2007
welcomejee
  • 10594 Answers
SOURCE: Camcorder Sony CCD-TR705E
Nops buddy,
You need to replace video head assy. Will be available at nearrest Sony repair shop.
Posted on Jun 03, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CCD-FX310 Camcorder how to adjust tracking
Sony camcorders has no tracking control for user.
I think video head is dirty / clogged. Put good quality video head cleaning tape in camcorder and check.
Its almost 15 years old camcorder.
Posted on Jan 30, 2009
SOURCE: sony fx310 handycam
Just Clean yer Head with a cleaner cassette, get the type that does wet the dry... If that don't do it then you will need to replace the transfer belt that rotates the tape spindle as it probably isn't turning it at the right speed due to loss of its elasticity.
Posted on Feb 25, 2009
ginko
  • 19396 Answers
SOURCE: manual for camcorder/sony-hi8 camcorder-ccd-trv68
Try the link below:
Video Camera Recorder
Posted on Sep 08, 2009
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
Panasonic camcorder playback and recording problem
We need more details on the problem,
Does the camcorder stay on, or it switches off , when the recording stops ?
Aug 30, 2008 | Panasonic NV-DS65 Mini DV Digital...
No playback after recording
check if you are using with a full battery..
if yes reset the unit and try again..
To reset the Camcorder, remove the battery from the Camcorder, press the Power button for 30 seconds and then reinsert the battery in the Camcder.
Dec 12, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
My sony wount record or playback a movie, there is a blinking symbol when i hit record.
I'm Sony tech and can help you to solve problem of CCD-TR818 camcorder.
Tap bottom of camcorder few times with your palm gently, now check playback of tape.
If problem still not solved, let me know what error code flashing on top right of view finder screen.
Thanks.
Dec 04, 2010 | Sony Handycam CCD-TR818 Camcorder
GR-D71, no longer records images
CCD (imaging chip) went bad and require replacement. Not a very expensive repair, but has to be done by professional.
Nov 04, 2009 | JVC GR-D71 MiniDV Digital Camcorder
Either my computer or dvd does not read movies recorded by this camcorder. Why?
hi. in many DVD camcorders. you are suposed to closed o finalize the dvd disk . by doing this it will be playback compatible with your pc or dvd player.
NOTE
after finalizing a disk you will not able to record any longer on that disk (DVD-R, DVD+R, DVD-RAM, DVD RW) If you record for 5 minutes and finalized the dvd it will have a 5 min movie !!!
Oct 08, 2009 | Canon DC20 DVD Camcorder
Videos are no longer showing on mini dvd in camcorder.
please try to play the DVD disk in a DVD player. I dont think that the video was wiped , but i think the camera has a defect in the playback software.
rgds,
Luwangula
Sep 14, 2009 | Canon DC310 DVD Camcorder
Problem with Sony CCD TRV138 camcorder
Symptom shows bad CCD IMAGER in camera and requires replacement. (IC951 on CD-465 board, mounted at end of lens mechanism).
Nice to know that you are tech person so buy CCD IMAGER from any part store under following part number..
A-7013-219-A CCD BLOCK ASSY (CCD IMAGER) (TRV138/TRV338)
Good luck.
Mar 15, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Jan 30, 2009 | Canon ES75 Camcorder
Video Cameras Logo
94 people viewed this question
Top Video Cameras Experts
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
