Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Hampton bay fans
I have 2 fans in two rooms when I turn on the fan in one room the lights on the fan in the other room comes on How do I correct this?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 31 Answers
You need to change the coding on one of the fans. You can do this by finding the code switch in the fan and the separate remote control and changing one of switches on each to a different same setting...
Posted on May 28, 2010
    Problem Solver:
  • 8 Answers
6ya staff
SOURCE:
We have the hapmton bay 52 in cameron II plus in chrome and blue neon fan. Is there a different light fixture that can be attached instead the neon light fixture? The fan still works great, but we dont...
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Feb 18, 2011 | Hampton Bay 52 In. Cameron II Plus in...
I have a 4 blade HB cieling fan. 2 above 2 blades. Where to put the reciever seems to be no room. Instructions were missing.
The receivers in my 3 hampton bay fans actually slides into the upper portion of the hanging bracket ( the thing you screwed into your ceiling fixture that the fan hangs off of)..
It fits rather nicely once you make room for it with the wiring etc
Hope this helps.
Jul 07, 2009 | Hampton Bay 24002 Ceiling Fan
I have the Hampton Bay 5-Light Track Lighting
Skill, patience, preseverance, and experience. You ned to cut and strip the wires so they "just fit" into the space provided leading to the connectyion screws. no room for stuffing , and no extra wiggle room for and bends or kinks .. You mightb try mounting the wires and then pushing the extra wire back up intio the ceiling junction box, thats what I do.
May 10, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Hampton Bay Ceiling fan wobbling
The fan came with one or more clips and some small weights that easily stick to the blade. Now with the clip you put it in one of the blades, starting from the far end and coming inwards, little by little. Try putting the clip in the middle of the fan and turn on the fan and see if it continues wobbling, if it continues wobbling try moving it to left and right and every time turn on the fan and see what happens. When you find the correct spot, there you glue the small weight.
Apr 09, 2009 | Universal Remote Control Hampton Bay...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
In our new home we have 3 Hampton Bay ceiling fans with lights. The lights with remotes turn on when we are trying to operate one in another room. Is there a code that can be changed so this does not...
In the wall transmitter (switch) and in the receiver are frequency switches. It's a bank of 4 tiny on/off switches. They can be set so each fan is different. The receiver and the transmitter must be set the same. So, as an example, you could set one of yours as follows ( 1 means on, 0 means off): 1110 - another one 1101, and the third 1011.
Sep 03, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote control
in the remote and the fan the little blue box is called a dip switch
you will have to open fans base to access the remote power sender
on both the fan and remote the dip switches have to match in order for the remote to work the fan properly
or your signal will never make it to remote box
Jun 05, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton bay fans
inside the remote, and inside the transmitter above the fan there are 4 tiny keys that set the frequency. set each frequency different then the remotes will only operate that fan. However if two lights r on and one off, when u turn the switch off they all go off, and when u turn it back on the same ones should come on. Then label the remotes!!!
Jun 04, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
249 people viewed this question
Top Universal Remote Control Televison & Video Experts
Christopher Stearns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
