Is it possible to do this or will I have to send it away to get it done???because I am studying web design at uni the programs I use are very big and the C drive size just disappears....or can you run programs from the D drive??? thank you for any help any one can give me...
Hey there gothicarcher, this is possible to do on your own. you will need to purchase an external drive case, that does exact copies of drives. You can also use this as an external drive when you are done. You could buy a kit for upgrading that also provides the external drive case and the data copying software you will need ( EZ Upgrade kit ). Next cleanup your old harddrive of any unwanted files, and defragment it. Next, mount the new hard drive (ensure it is compatible with your laptop) in the external case. Connect it to the laptop and transfer the data. Next turnoff laptop, remove battery, and following instructions in your manual, open laptop to access the hard drive. Remove it paying extra attention to the way it mounted and any guides that may be attached. Switch guides from old to new and place new hard drive ensuring all connections are made. From here you are good to go. The old harddrive can be mounted in the external case and used. By the way, you can run programs fom an external, but they still use up some admin space on your main hardrive and the speed of the program can be hindered due to the limitations of the connection, causing the occasional stall. Good Luck! p.s. ensure you have the manuals necessary and follow all software recommendations. Lost data can hurt. Back up on disk anything that can't be replaced easily
HI - MY ACER ASPIRE 3050'S SCREEN JIGGLES. Just started happening 2 days ago. Now sometimes the...
(More)
HI - MY ACER ASPIRE 3050'S SCREEN JIGGLES. Just started happening 2 days ago. Now sometimes the screen freezes and / or the screen gets too white for about 10 seconds then comes back to normal (but still jiggles). A techie told me it is probably a $30 part that needs replacing (he said it was a pretty common problem) but he didn't describe the part or the process too well. Some kinda linkage from the motherboard to the screen. He said that if I connected my laptop to an external monitor via VGA or whatever, and if there were no issues, that would suggest the linkage problem. Otherwise, maybe the motherboard had a problem. HELP!!!!
i want to restore me factory setting on me acer aspire 3050 on vista but dont no what to do once ive...
(More)
i want to restore me factory setting on me acer aspire 3050 on vista but dont no what to do once ive pressed alt and f10 can you help me thanks
