Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Turn off closed caption on input(component) on Sharp Aquos 42"
We just bought the new aquos and hooked up the hdtv, but now in most of the HD channels closed captions show up and we don't know how to get rid of them. We tried pressing the cc button like the manual said, but it isn't the same in a different input. We want to take the subtiles off. How can we turn off the closed caption in input 1 (component)?
My problem is somewhat similar. We just purchased a Sharp Aquos 32" HDTV. I've connected the cable ( Comcast) to the tv with component cables. The close caption on the analog channels works fine, but on the HD channels I'm not able to turn CC off unless I power down the cable box (Motorola) and press menu, and then disable the CC. I'm thinking that a HDMI cable might fix the problem.
  • 4 more comments
  • Anonymous Apr 08, 2008
    I have the exact same problem. Need to get the procedure for turning off closed captions from Comcast.
  • Anonymous Mar 04, 2009
    We have the same tv, but with the reverse problem of not being able to get captions to come on with satellite tv. Can anyone tell me how to get to come on for my mother in law who needs the captions on certain days that she watches the baby?
  • Magnolia Cunningham May 16, 2013
    I have the issue with not being able to get CC with the exception of on 1 HDMI input all others will not get CC please help
  • Anonymous Mar 13, 2014
    The cc doesn't turn on in the TV
  • Anonymous Mar 23, 2014
    can't get digital cc to work
  • Anonymous Mar 25, 2014
    We have a sharp aquos and while watching tv everything turned to snow We have checked all connections and gone through every option in the menu No inputs are working Tv input just says analog We have tried changing it nothing Please help
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
    Champion:
  • 208 Answers
Unfortunatly with all these products, while using Hi Def. the Comcast receiver is where the closed caption is produced. You cannot turn it on and off with the remote. You must either have the cable receiver enabled and have closed caption all the time or disable it in the receiver and not have it at all.
Posted on Feb 03, 2008
Ask cable company than get a procedure to on off HD CCs.
Posted on Mar 18, 2008
2 Suggested Answers
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
ok had to post this one with reference to the above problems
My area St Augustine Fl. .. COMCAST (THOSE PAIN IN THE A--) SERVICE INSTALLED A NEW BOX IN MY HOME THE OTHER DAY ... I KEEP SEEING the box go thru dowmloads
then the very next day I started to see the colosed caption across my screen
SOLUTION ... with tv on and box on ( be in cable mode) press MENU on cable remote ,press power button, press menu again, look at screen and where it says caption make sure it is disabled
Mine was enabled ... change it and problem fixed ... I spoke to comcast finally after trying all day and they confirmed that with their new down loads to box it triggered the CAPTION to be ON
anyway problem was fixed ...
I read all prevoius posts and tried them all ... so may be this will work for problem that someone is having as of 10-9-2008 ( I could not believe that they could do that but they sure can COMCAST is just a PAIN in the A--
thanks to all who post solutions and I had to do my share and maybe be able to help someone else.
Posted on Oct 10, 2008
Can't turn off the closed captioning
I had the same problem. Okay, First get the TV remote. not a cable box remote. Next, switch the input to an Analog input. (TV or input one if you have the RC red, white and yellow hook up. or, just hook up the coax cable straight to the TV..
Now, use the TV remote to operate the closed caption. It will work like it should.\
Briefly, closed caption works on the TV with a straight hook up to the TV. It will not work with a cable box.
Good LUCk
Monty
Aug 21, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I get a large black rectangle covering 1/3 of my
Is closed caption turned on? (and the channel doesn't have any captions) Turn it off.
Mar 27, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Closed Caption TV
Check your remote for a button marked SAP or CC.
Jul 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Apr 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Blink on Sharp Aquos LC-32D43U
If your using a HD converter box, there is usually a blink when switching from an HD channel to a non HD channel. It is just adjusting from different pictures modes such as changing from a 480i channel/show to a 1080i channel. If this is the case, its perfectly normal.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't turn of Closed Caption
check to make sure they are not on auto
Dec 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This is what just worked for me. If I can figure this out, anyone can :) We have comcast cable hddvr box, motorola 3416, and a new Samsung HD Plasma, but try this no matter what you have...
turn your cable box off, and THEN press menu on the box. A white screen popped up and this is where I had to scroll down to and disable the captions. I couldn't believe this worked since I thought the cables were enabled on my TV since my captions were covering my cable menus, but it was the cable. I hope this helps.
Oct 23, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
6,897 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
