Question about JVC GR-D73E Mini DV Digital Camcorder
JVC GR-250U Camera says lens cap is on. Sometimes goes on safeguard mode
  • rddavis05 Jan 30, 2008
    The code is 03. Is the CCD base assembly easy to replace by an ameteur?
  • kennethsolli Aug 30, 2008
    safeguard mode e03 is shown on my videocamera display,how to unlock?
Where do you get CCD sensors?
Posted on Feb 13, 2008
  • 156 Answers
There should be a cose number when it is showing safe gaured mode.what is that.For the lens cap may be there is loose contact with ccd cable or you have to change CCD base assumbly.
Posted on Jan 29, 2008
  • JAYA SANKAR
    JAYA SANKAR Jan 30, 2008
    Yes this is some thing simple to replace but take care when changing the chip capacitors and resistors are near by the ccd ic pins.
    In the case no REEL FG is
    produced for seconds shown in the
    table below or more in the capstan
    rotation mode after loading was
    complete, the mechanism mode is
    shifted to STOP with the pinch roller
    set off. This error is defined as
    [E03].However, no REEL EMG is
    detected in the SLW/STILL mode.
    1. The idler gear does not engage with the reel disk well.
    2. Though the idler gear and reel disk are engaged with
    each other, the tape is not wound because of overload
    to the mechanism.
    3. No FG pulse is output from the reel sensor.
    4. No power is supplied to the reel sensor.
    5. Tape transport operation takes place with a cassette
    having no tape inside.
    6. The tape slackens and no pulse is produced until the
    slack is taken up and the tape comes into the normal
    status
My JVC GR - D290 says that the lens cap is on when the lens cap is off
Open and close it a few times. Maybe tap the side a little bit as the lens cap switch may be sticking.
JVC GR D290 Manual
Jan 06, 2013 | JVC GR-SXM260E Camcorder
I HAVE A JVC GR-D820EK MINI DV VIDEO CAMERA AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE...
i HAVE A JVC GR-D820EK MINI DV AND IT IS DISPLAYING UNIT IN SAFEGUARD MODE 06, I HAVE TRIED REMOVING BATTERY AND DC PLUG BUT NOTHING HAPPENS IT WILL NOT WORK ON EITHER PLAY OR RECORD, PLEASE COULD YOU ADVISE
Feb 11, 2011 | JVC GR-D775, GR-D790, GR-D796, GR-D820EK,...
I have a GR-D850U in safeguard mode
I have a GR-D850U model JVC and its giving a message Unit in safeguard mode. How can I have this fixed ?
Jan 14, 2010 | JVC GR-D850 Mini DV Camcorder
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
"Lens cap on" error on JVC GR-290AG DV camera
Check customer support on the JVC website - there has been a massive worldwide problem with the CCD IC which causes the symptons you describe. They may repair free of charge even if out of warranty.
Jul 06, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
E03 safeguard mode
look for a tiny pinhole and insert a pin while powered up to reset
May 27, 2007 | JVC Cybercam GR-DV800US Mini DV Digital...
JVC GR-D73E Mini DV Digital Camcorder Logo
306 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
