Question about Samsung YP-U3 MP3 Player
Mp3 froze my samsung yp-u3 2gb has frozen gow can i sort that out
  • 3 more comments
  • sly1 Feb 08, 2008
    My mp3 player is frozen and the volume is the only thing displaying on the screen. It will not shut up off. Its completly frozen. Please advise.
    Thanks
  • JizzyG Feb 14, 2008
    log val = 0x10000024 or log val = 0x10008035 is the only thing displayed. i have held rec button down but got system faild notice and shut down. S.O.S. need help
  • Anonymous Feb 21, 2008
    Mine has also completely frozen with the screen on. Not responding on USB or it wont turn off!!!
  • pri pri 15 Mar 22, 2008
    my samsung yp-u3 is frozen on a song with a light glow
  • shrinandiyer Aug 03, 2008
    guys... my system is fixed thx for reseting technique... but isnt reset supposed to remove all data???
    but my data was still there... ny ways thx guys...
Try resetting the system
put the mp3 player on hold then press and hold play&rec.
Posted on Feb 01, 2008
  • kremi Sep 26, 2011
    THIS FOR SURE HELP!!!!!!!Hi...I find the answer...Push and hold rec button and button for holding...And it will start..if your mp3 (a samsung yp-u3 mp3) says log val=0x10008018 or something, click and hold the record button and once it begins to record, press the back arrow/button (symbol in the top right corner). your mp3 should work (play music and such) now. to fix your mp3 and get rid of that log val message, you need to go to settings, then system, then format. format your mp3. unfortunately this will delete all your songs and files on the mp3, but the mp3 player should be fixed and the log val message wont appear anymore.
    hope this helped....
Mine didnt work eithr, all i can see was Ox00000024, So i tried what other's said "put the mp3 player on hold then press and hold play&rec" but that didnt work, the only thing showed up was "system fail, power turned off" etc.
SOLUTION:
-go to windows Media Player
- click "syn" & press the down arrow
- then click "shuffle samsung YP-U3"
- Click yes
just let it delete the files, you can always put songs back into the MP3, this was the only way i found it easy :)
hope this helps!!!!
Posted on Dec 28, 2009
Yeah, i just went through the same problem but was able to fix it by synchronizing my yp-u3 with windows media player 11.
After this i just took my mp3 player out, without safely removing it, and turned it on and it worked just fine, not showing the log val = 0x0000024. If this does not work you could try:
-formatting your u3
-downloading and installing the samsung media studio and formatting from there
-upgrading your firmware for your u3
These were some methods i used to try fixing my u3 but did not come to any prevail.
Hope this can help you.
Posted on Feb 20, 2008
My girlfriends mp3 had the log val = 0x....... error also and i fixed by simply formatting the device using samsung media studio 5. I tried resetting (player on hold and holding both top buttons) but that didn't work.. The firmware i use is 1.13.
Goodluck everyone!
Posted on Jan 21, 2009
  • 3 Answers
Hi I had the same problem and the reset procedure did not work. I discoved that the hold was on and the unit will not reset with hold on. One I removed hold the rest procedure worked.
Posted on Jan 02, 2010
  • maxis2034 Jan 02, 2010
    Hi I had the same problem with the same unit.
    I found that the reset produre will not work if the hold is on. I turned the hold off and the unit reset and is all working again.
Resetting is not solving the problem
I am sorry to say that your best bet is to get a new one because the cost of repair is not worth it.
Jul 01, 2009 | Samsung YP-T7 MP3 Player
Mp3 froze up
Take the battery out and put it back in.
Nov 30, 2008 | Samsung YP-T9JQB Digital Media Player
My samsung yp-s5 has frozen when i was sliding out the speaker
You may want to reformat the memory.
If it persists try hitting reset(slide the speakers and you will see on the back a hole with reset written on it and push a pin in it)
Oct 15, 2008 | Samsung YP-S5JAB MP3 Player
Yp-k3 samsung Mp3 Screen Froze On "Remove Cable"
My daughter had a similar problem - she was frozen at the power off screen. On closer inspection, at the bottom of the K3 on the back of the unit is a reset button (you will need a pin or paper clip to reset it). Pushed a pin in for a few seconds, reset, all was OK.
Aug 21, 2008 | Samsung YP-K3 MP3 Player
MP3 player has froze at startup screen
Reset, upgrade firmware:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
Mar 25, 2008 | Samsung YP-K3 MP3 Player
Mp3 froze completely
press the reset( small hole on back near bottom) with a small paperclip
Mar 01, 2008 | Samsung YP-U3 MP3 Player
My Saamsung M3 YP K5 has frozen and refuses to operate - frozen
im havin the same problem my ones worse when i turn it on its frozen all i can see is white the menu doesnt appear can anyone help me fanks
Feb 11, 2008 | Samsung YP-K5 MP3 Player
FROZEN
Hold the power button for about 15-20 seconds so the device can reset..get the latest firmware update for the device..
Jan 05, 2008 | Samsung Yepp YP-T9 Digital Media Player
My samsung yp-t8 is frozen onto 1 pic
Have you tried reset button on bottom of your player, open the small clip where you recharge and you will see the small hole there. Also be certain your hold button is off.Good luck. Pedro2
Oct 19, 2007 | Samsung YP-T8 Digital Media Player
Samsung YP-U3 MP3 Player Logo
1,243 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
