Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Damaged front Panel on Samsung washer WF206ANS, Where can I get one
I recently got a Samsung washer WF206ANS but the front panel is damaged. I would prefer to replace it but I am not sure where to get the panel surrounding the front door. Any suggestions?
  • elagodz Jan 30, 2008
    Hey thanks for the advice but we bought it damaged. It was on clearance but I wanted to repair it. Sort of like someone who buys a car that was in a wreak but wants to restore it. Any other suggestions on where I can locate the panel?
  • 5,911 Answers
If you purchased this appliance NEW, I would strongly recommending getting in touch with the company that you purchased it from. Any damage should be covered under a manufacturer's warranty and should be replaced by them. The reason I mention this to you is because many of the front panel pieces (although plastic) can cost a lot. Especially door facing trim and control panels. You can do the research yourself at repairclinic.com. Type in your model number and use the part index of photos to see if you can identify the part you need. It doesn't makes sense for you to repair something out of pocket if it is a new applaince. AND....if it was possibly damaged during delivery (if this is the case). Post back with your comments and let me know if I can be of further assistance. I hope this helps.
Posted on Jan 29, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 30, 2008
    Try repairclinic.com and type in your model number in the search window. There should be a pictorial index of parts available. I hope this helps you.
6ya staff
SOURCE:
Where is fuse for 1997 mercury wagon for windshield wipers
1997 mercury wagon ? Sable ? VISUAL INSPECTION CHART-WINDSHIELD WIPER AND WASHER SYSTEMS Mechanical Electrical
  • Windshield wiper blade missing or damaged.
  • Binding windshield wiper pivot arm.
  • Binding windshield wiper mounting arm and pivot shaft.
  • Empty windshield washer reservoir.
  • Kinked or broken windshield washer hoses.
  • Open fuse junction panel Fuses:
    • 8 (5A)
    • 12 (5A)
    • 20 (5A)
    • 23 (5A)
  • Damaged windshield wiper motor.
  • Damaged windshield washer pump.
  • Open connectors.
  • Corroded connectors.
  • Inoperative multi-function switch.
  • Open thermal breaker internal to the wiper motor
Which are not working , front , back or all ?
I/P Fuse Panel C225
Under left corner of instrument cluster
Feb 05, 2017 | Mercury Cars & Trucks
I just got my pump replaced and now i need to reset my samsung washer it still shows nd and stops
The problem is probably in the control panel or water level switch. I just posted a procedure to clean the relay contacts for the pump motor relay. This little relay is on the control circuit board and is not normally customer accessible. But the alternative is purchasing a new control circuit board (which in my case was not available) or replacing the washer. Please refer to my solution for the problem "Drain Pump doesn't work" posted today.
Oct 18, 2014 | Samsung WF206ANS Front Load Washer
What size belt do i need two pulley 38 inch cut
Washer belt aren't givin out on size, they are model specific. Because not only circumference but thickness and compound so use the washers model / serial number to get the correct one
Jun 01, 2014 | Samsung WF206ANS Front Load Washer
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
Samsung vrt front load washer will not spin out, ( not working)
I have the same washer and mine wouldn't spin out all the way sometimes leaving the clothes very heavy and wet. My problem was that the drain hose from the washer that you put inside your drain pipe had created a suction preventing it to drain properly. It might be worth checking. I know for forking out so much money on the thing it sure can be finicky.
Apr 18, 2012 | Samsung WF206ANS Front Load Washer
I have a wf206ans machine and today i had error code that looks like (be) or (he) i cant find the manual for this machine .this code appears on all cycles for the machine washing or spinning only . any...
The manual for the WF206ANS is available here: http://downloadcenter.samsung.com/content/UM/200701/20070131100335625_WF317AA_XAA_02291A.pdf . The table with the code list is on page 22 of the pdf (page E-3). A bE error is a motor speed sensor error. If the code reappears when you restart the cycle, then the washer needs service. For other codes or for service, call 1-800-726-7864 (1-800-SAMSUNG).
I hope this helps.
Mar 27, 2011 | Samsung WF206ANS Front Load Washer
I have a front louder newer model samsung washing machine. The door was forced opened during cycle and now the lock is still in the locked position and I cannot reclose the door or get the locked to unlock...
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Sep 01, 2010 | Samsung WF206ANS Front Load Washer
I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Dec 31, 2009 | Samsung WF206ANS Front Load Washer
Not spinning or draining Samsung front load wf206ans/xac
Won't spin if it hasn't drained. Most probably a blocked/jammed pump impellor. Manually drain it from the lower drain pump (by side tube if that model has one, or slowly into a shallow pan. Remove cap completely & check for things jamming pump.
Dec 12, 2009 | Samsung WF206ANS Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
110 people viewed this question
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
