Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Creative zen xtra 60gb
My creative zen xtra 60gb has frozen-the navigation wheel won't respond and when you can get to play music it cuts in and out and stops playing the track after a couple of seconds.Have tried resetting but no luck.The battery is fully charged.
Mudda kudu
Posted on Jan 29, 2008
Creative zen became frozen
Let the battery completely drain, and after a while charge it using the charger available else thru computer without turning it on.. let it charge for 50% and then try switching it on. Try this if not get back to me.
Jan 21, 2010 | Creative Technology Zen MX Black (8 GB)...
Creative zen xtra 60GB mp3 player question...
First thing I'd do is compare the sound coming from your MP3 player to the sound of the same songs playing from your computer speakers, to eliminate any possiblility of the audio files being at fault (I realise you haven't altered them yourself but they could be faulty at source)
Then check the graphic equaliser in your player and see what the current setting is. Most audio devices these days come with a range of presets and these often include a karaoke setting so I'd check thats not been toggled by mistake.
Then have a play with your EQ settings to see if you can bring the vocals back up in the mix, vocals tend to lie in the 1-2kHz range of the audio spectrum so give it a boost in this region. You might also want to try cutting the bass end, too much bass energy in a mix can steal your headroom and lead to parts dropping out unpredictably like this. N.B. if your player only offers EQ presets rather than a proper hands on EQ then look for presets with names like Mid boost or Bass cut, even a general POP preset should be OK, just avoid things like Dance, Hiphop and the like.
Dec 04, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Xtra Error Message When Creating Playlist
The only solution I know of is to reformat the hard drive. It's pretty time-intensive, but it does work. I use Notmad to back up the playlists. Once restored, they all work, even the ones that had initially failed.
I've never had the problem on my 60GB Zen Xtra (non-upgraded hard drive), only with my 120GB, so my naive guess is that the problem may be caused by the machine somehow not handling the extra hard drive space properly.
Also, both times it's happened, I've seen a warning sign: I usually have a lot of stuff loaded into "selected music", and when I add another album or two it partially clears the selections. And it does so in a weird way: only a few selections remain visible, yet it keeps playing at least some of the now-invisible selections.
I'm starting to think it's time to switch players, and maybe get something I can put the Rockbox OS on.
Feb 02, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Nomad Jukebox Zen Xtra Display Failure
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 25, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Full Data not showing on the Nomad Zen Jukebox.
When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Mar 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Player Turns On, but Won't Play Music
Yo fud, go to www.creative.com and search through the Knowledge Base. It should point you in the right direction.
Feb 12, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
114 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
