Question about Canon ImageRUNNER 330s Copier
Canon Imagerunner 330s - Stack Bypass
We are having a problem with our Imagerunner 330s. It will not allow us to keep the Auto paper select function. Instead the copier thinks there is something in the stack bypass. how can we get it back to Auto without having to manually punch in the letter size?
  • Anonymous Mar 13, 2014
    error code e100 on canon imagerunner 330s
  • 37 Answers
You can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Posted on Feb 05, 2008
How to clear RAM using factory settings in CANON IR330 machine?
ir 330 and ir 400,gp 405 r same machine,turn on the copier when its ready to copy press the additional function then press (2 and 8 both r same time) again additional function when this process is completed copier on the screen select that in the screen find the 'function' select then select on clear in clear menu select one by one err and other all function like dc-con and press ok after se;ect one by one..
Sep 02, 2011 | Canon ImageRUNNER 330s Copier
I have a canon imagerunner 330s. It reads load paper and it is already full. Is there a sensor that went bad?
Sounds as though the lifting mechanism for the paper Pick-up assembly has gone bad. When closing the paper cassette you should hear a ratcheting sound, this is the lifting of the paper to meet the paper pick up rollers. It should stop and the display should indicate paper is present. If it continues to ratchet and never indicate the paper is ready, then the P/U assy will be the problem. The whole paper pick-up assembly will have to be replaced. In all my years of working on this model, I never successful in repairing the assembly.
Jun 27, 2011 | Canon ImageRUNNER 330s Copier
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
that is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
May 18, 2011 | Canon ImageRUNNER 330s Copier
The machine keeps changing the orientation when you place the papers to be copied on the glass. how can you pick the one you want?
enter additional function(*); on screen, select copy settings>auto orientation> off>ok.
switch off the machine and re start.
place original according to the orientation of paper in paper tray and make copies.
Feb 08, 2011 | Canon ImageRUNNER 3235 Black and White...
I have a canon imagerunner 330s copy machine. I'm
Hello sir;As your descript, it seems need to replace drum blade, if they come with whole cartridge then replace whole cartridge.
May 12, 2009 | Canon ImageRUNNER 330s Copier
Imagerunner 330S - just received this copier as a donation (we're a small nonprofit). Machine claims there is a paperjam in paper tray and side drawer. Doesn't seem to be paper in either location. Any...
check whether any sensor spring will open under stack bypass area, under toner area or under back panal fixing area or any short piece of paper in way of paper feeder
Feb 09, 2009 | Canon ImageRUNNER 330s Copier
Imagerunner 330S
this is the webb code for your fuser unit you have wo things to do in service mode 1st claer webb count touch counter misc webb clear key in that order then in this order function clear err ok turn off then on main switch
Dec 01, 2008 | Office Equipment & Supplies
CANON IMAGERUNNER 330S TOUCHSCREEN
Start with service mode, Additional functions(looks like * key), then 2,8 together, then addit. func. again. Has to be a fluid motion. If done right you will see a screen with copier, and whatever options the copier has. Hit copier key. Hit function key. Hit panel key. Hit touch key option, hit OK. Then touch the nine + signs. once complete. press reset to get out and test results. Hope this helps.
Jun 13, 2008 | Canon ImageRUNNER 330s Copier
1,471 people viewed this question
old marine
old marine
