My Toshiba 36ZT29B
For some reason my Tv seem to cut out briefly giving me a blue screen then goes back to normal, does this about every 10 to 15 minutes. Any idea what could be causing this? I had an engineer come out and have a look but he had no idea. So please help. Thank You
    Problem Solver:
  • 40 Answers
Does it do it when playing a DVD...or Cable..or all inputs
Posted on Feb 01, 2008
6ya staff
SOURCE:
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Toshiba television, rear projection, HDTV. - Model #: 50H13 - Serial #: 15703904 - Chassis #: TAC 0360 Blue horizontal arcing line about 1/3 from bottom of screen, a few inches thick. Text...
ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Sep 15, 2008 | Televison & Video
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Televison & Video
I have a 26' Toshiba LCD TV Model: 26WL65G. When I plug in and turn it on it seems to start normally, but when screen turns on blue screen appears as normal and it goes back to stand-by mode...
Note that if it is a backlight inverter board problem you will still have sound. SInce you have no sound I would suspect a power supply or main A/B board malfunction. Do you know how to use a multimeter?
Dec 11, 2011 | Televison & Video
Blank blue screen
check truner and cable see if broke
Jul 18, 2010 | Toshiba 26HF85 26" TV
Toshiba 43a10 has an intermitent blue screen
it must be because ur tv is not being serviced regularly
cos the chips get fungus growing on it it happened to my
tv too its is 55" toshiba rear projection so get it to an toshiba repair centre.
Aug 13, 2009 | Toshiba 43A10 43" Rear Projection...
Tv turns blue the shuts off.
symptom shows Blue CRT (picture tube) in your TV might defective and need to be replaced. Its high tech repair issue, so contact tv tech person if you don't have enough knowledge about tv repair.
Sep 05, 2008 | Toshiba 51H84 51" Rear Projection...
Screen is black except briefly blue upon power on or putting source on "VGA"
Your backlights power inverter board is what causes this prob. It is a Darfon V144-001.
Dec 30, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Toshiba 36zt29b television
Hi, I am an idependant service engineer, who is currently looking at one of these actually a 36 inch 36zt29b. So far, it looks likely the digital board is at fault sending an 'off' signal to the digital power board. The digital board itself is no longer available. I am going to have a look at this board, and try to fault find it. If I have any success I will post again.
Oct 26, 2007 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
