Noisy kickspace heater
I have an old hide a vector kickspace heater, recessed and vertically installed in the kitchen of the house I just bought. I called Embassy industries and thry told me that the model is 30 yrs old and they have no information on it at all...Go Figure...The fan is getting progressively noisier. I assume it needs lubrication...how and where can I lubricate it? If thatis not the case what else can I do besides replace it?
I fixed mine today but it is not what you think. It's a rubber grommet that has dropped out of the squirrel cage fan and allows the rotating fan to rub on the housing. I also thought it needed oil,but after three years of noise, it finely dropped off the motor- shaft, rendering it non functional. So to access this I took the cabinet out to trouble -shoot.This was easy in my case because I engineered the cabinet as such for Hide-A-Vector servicing.
My fan has a square punched hole in the fan side metal that indexes a small rubber grommet with a center hole.The hole accepts the motor shaft while frictional compression holds the whole mess together.Take it apart to work it.
Carefully re-insert the grommet in the sq. hole being xtra careful
not to push it inside the cage.Once in place,drip runny epoxy glue
through the open fan fins so some settles around the grommet.Use a light to verify target grommet.Once cured, put some on outside as well. Let that fully cure. Re-install on shaft so fan spins freely.
Footnote: My model ----HAV 48/ HAV 88--- 8 yrs. old
Posted on Jan 13, 2009
  • 625 Answers
It probably is a sealed motor but if you have access to it you may be able to oil it with a very thin oil - like 3 in one oil. the bearings are undoubtedly oil-lite which is a porous bronze bearing pressed into the end bells of the motor. for fractional horsepower motors I'd go to grainger dot com to see if a replacement can be found.
Posted on Feb 02, 2008
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
What best flooring for kitchen large dogs
Better Ceramic Floor Tiles where can easily clean.
Apr 13, 2015 | Building Materials
Need to change thermostat and housing in a 2001 jeep cherokee I4 4.0L.
Hi there:
It is located at top front center of engine:
  • Remove radiator upper hose and heater hose at thermostat housing.
  • Disconnect wiring connector at engine coolant temperature sensor.
  • Remove thermostat housing mounting bolts, thermostat housing, gasket and thermostat. Discard old gasket.
  • Clean the gasket mating surfaces.
  • To install:
    1. Install the replacement thermostat so that the pellet, which is encircled by a coil spring, faces the engine. All thermostats are marked on the outer flange to indicate the proper installed position.
    2. Observe the recess groove in the engine cylinder head.
    3. Position thermostat into this groove with arrow and air bleed hole on outer flange pointing up.
    4. Install replacement gasket and thermostat housing.
    Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
    Thank you for using FixYa, have a nice day.
    Aug 17, 2012 | 2001 Jeep Grand Cherokee
    What is vector masking ? how can use it?
    Using Vector Masks Let's look at the different ways that a vector mask can be used, created, and/or edited:
    · Add a vector mask that shows or hides an entire layer
    · Add a vector mask that shows only the content inside the shape that has been created by a path
    · Edit a vector mask that is already created
    · Remove, disable, or enable a vector mask
    · Convert a vector mask to a layer mask (rasterize the vector data)
    Additionally:
    · To add a vector mask that hides or shows an entire layer, select the layer from the Layer palette that you want to add the vector mask to. Choose Layer>Add Vector Mask>Hide All or Reveal All. (If these are grayed out, make a copy of the layer first.)
    · To add a vector mask that shows the contents of a shape, select the layer to apply the mask to in the Layers palette, select the path from the Paths palette, and choose Layer>Add Vector Mask>Current Path.
    · To edit a vector mask, click the vector mask thumbnail in either the Layer or Paths palettes. Edit the mask using the Shape or Pen tools.
    · To delete a vector mask, select it and choose Layer>Delete Vector Mask.
    · To enable or disable a vector mask, select it and then choose Layer>Enable Vector Mask or Layer>Disable Vector Mask.
    · To convert a vector mask to a layer mask, choose Layer>Rasterize>Vector Mask.
    Feb 21, 2011 | Adobe Photoshop CS5 Upsell from Photoshop...
    How to replace thermostat on 1998 Maza b2500
    I have generic instructions here: http://www.fixya.com/cars/r5929960-s_thermostat
    Specific instructions from autozone.com are below
    2.5L Engine
    1. Disconnect the negative battery cable.
    2. Drain the cooling system.
    CAUTION When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
    1. Disconnect the heater return hose at the thermostat housing.
    2. Disengage the ECT sensor and engine coolant temperature sender wiring connectors.
    3. Disconnect the upper radiator hose from the thermostat housing connection.
    4. Loosen the mounting bolts and remove the housing from the cylinder head.
    5. Remove the thermostat and gasket from the housing.
    6. Clean both thermostat gasket mating surfaces.
    To install:
    1. Position the thermostat gasket properly onto the housing. The gasket must be in place before the thermostat is installed.
    2. Install the thermostat into the housing by first turning and then locking into the recess of the housing.
    3. Position the thermostat and housing onto the mating surface of the cylinder head. Install and tighten the retaining bolts to 14-21 ft. lbs. (20-30 Nm).
    4. Connect the upper radiator hose to the thermostat housing connection.
    5. Connect the ECT sensor and engine coolant temperature sender wiring harnesses.
    6. Connect the heater return hose to the thermostat housing.
    7. Connect the negative battery cable.
    8. Fill the radiator and operate the engine until it reaches operating temperature. Check the coolant level and adjust as necessary.
    Sep 27, 2010 | 1998 Mazda Pickup
    My kids just bought an older home w/a rinnai continuum nc-45-4us. right now their house phone isn't installed, so they can't phone, but they can't turn on hot water. any suggestions
    Run through the basic checks
    • Power lead from the heater plugged in a socket turned on.
    • Gas on to house
    • All valves below heater in on position.
    • If they have controllers in the house turn on (key pads marked with Rinnai logo in kitchen or bathrooms usually)
    There is a turbine that spins in the heater when a hot tap is run. If the heater has been sat for some time not operating the turbine might have stuck. Run the hot tap and keep it running, using a hammer give the centre pipe connection under the heater a firm hit a few times(not too hard). This might unstick the turbine.
    Sep 21, 2010 | Rinnai Digital Remote Water Heater Control...
    We can not locate the switch for the hot water heatr in our 2009 Fleetwood Terra LX Morothome, can we get a manual for this unit?
    Wall by kitchen counter, or end of kitchen counter, near cabinet or counter on same side of motorhome as water heater, as well as a switch on the monitor panel itself. Some hide them on underside of kitchen cabinets as well.
    Jul 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
    Do I need the toggle switch when unit is on a thermostat? TSH20X
    the toggle switch can be left conneted, make sure it is on on.you could remove it but it doesnt matter if you do or not
    Oct 18, 2009 | TPI Set of: TSH20X and TSH1TX Fan Forced...
    Range unit stands too far away from wall
    There are mounting plates that recess the plug in the wall. Hardware stores have them in the electrical parts department.
    Apr 15, 2017 | Frigidaire FEF336BC Electric Kitchen Range
    MY heater So noisy
    grease the bearings before you burn your house down.
    Jan 04, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
    Heating & Cooling Logo
    1,971 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Marvin
    Marvin
