Question about Canon BubbleJet i560 InkJet Printer
I560 Printer fell of desk and now there's a loose piece inside
After the printer fell off desk (don't ask), I went to print something and it made an awful noise. I opened it up and on the right side, there was a plastic please that looks like an "L" just sitting there. On the front of this piece there are two icons-one looks like an envelope, and the other looks like a regular piece of paper. It has metal tabs that look like they'd insert into the printer but it's the where that has me stumped.
Thanks,
Heidi
h_krapfl@yahoo.com
  • 20 Answers
Time for a new printer....
You have damaged internal components beyond repair.
Posted on Feb 01, 2008
Something fell down in the lint vent. I didn't know it and turned it on. It made and awful noise and now it won't work.
That something is probablly now jammed in the blower fan. T o get to it you need to remove the front of the dryer and you will see the fan blades in the lower left corner. To do this: unplug the machine, open the door and remove the 2 screws that are located in the top of the hole. this will release the top of the machine, lift it up and then remove the 2 screws that are inside the front panal at the top 1 one on each side this will allow you to tilt the front panal outward and lift it off the 2 fingers that hold the bottom in, be carefull and don't yank on the wires that are connected to the door switches. look in the fan husing and recover whatever it was that you threw down there reverse the process for reassembly
Oct 19, 2011 | GE Dryers
I think i have a fuser error. When I print something the right side of the paper is very light in color. If I print multiple pages, it gets lighter by every page.
Put paper in the manual feed tray. Print. When the page gets half way into the printer, open the cover. Remove the toner. Look down at the paper. Is the right side lighter than the left? If yes, replace the toner cartridge. I don't believe that a fuser could cause your problem.
Aug 11, 2011 | HP LaserJet 4240n Printer
I have a hp 5150 desk jet that won't print. The task manager says "door open" which I see sometimes after I change out the cartridges. However, in this case I didn't. I've opened and closed everything...
Open the printer cover.From right side there is a plastic rod.It's connect to door sensor.This plastic rod often breaks from top.Look that and if it's broke try to fix it with glue or something else.
Nov 20, 2009 | HP DeskJet 5150 InkJet Printer
My hp laserjet 1320 fell off the desk and now will
check to make sure if the ink or your toner is install properly becoz it might fell of its correct position.
Oct 27, 2009 | HP LaserJet 1320 Printer
HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
Oct 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Mac leopard -epson tx400 - printer grabs paper - printer very noisy, desk shakes with vibration - now the print on paper is faded help!!
Hello, sorry to hear you are having trouble,
So, are we to understand that your printer did not shake with vibrations and make a lot of noise before ?
Most of these ink jet printers have heads that travel very quickly and abruptly from side to side causing shaking and vibrations, especially if it is on a light weight desk or table, sometimes to the point of almost throwing itself right off the table. This is a normal state for the printer to be in.
Then, you say the paper is printed on, it goes right through to the end, no paper jam, but the colors are faded...
How often do you print on this printer ? Sometimes, the Epson print head dry up and only small amounts of ink get through even though the system indicates that the ink is full...
You can certainly perform a head cleaning operation, I recommend doing it several (3) times to be sure, unfortunately, it's a terrible wast of ink.
Finally, have you replace the ink cartridges? If you get a faded output with new cartridges, you may have inadvertently activated the ink saving or draft mode, go through you page set-up or printer option thoroughly.
I'm pretty sure something here will get you out of this mess.
Mar 27, 2009 | Apple iMac 17" Desktop
Distorted printed documents
Try this steps first and these steps first :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 17, 2009 | Dell Photo 964 All-In-One InkJet Printer
Unable to print from web on Lexmark z2300
hi ..
log on to lexmark website..www.lexmark.com ...downloaded lexmark tool bar to ur desk top ...once download is complete .install tool bar...then open web page..don not print from file..instead use the printer icon on the top right corner to print...this should fix it
good luck
Feb 12, 2009 | Lexmark Z2300 InkJet Printer
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Apr 13, 2008 | Samsung ML 2010 Laser Printer
Canon BubbleJet i560 InkJet Printer Logo
old marine
old marine
