Crossover i think i got one crossover down on technics my sb-a10... how can i test it?? I have a multimeter at home. If not, can you have electrical schematics of it please!
  • pepinmax Feb 01, 2008
    Thanks a lot robotek, it works!
  • 1,512 Answers
Not alot to go wrong with a crossover. Putting your ear up to each speaker and listening to each driver can steer you to the problem area
  1. Dry solder joints often affect a crossover on a pcb. check all soldering and res-older if you can anyway.
  2. Coils and inductors seldom fail on a crossover. They can be checked with an ohms meter.
  3. Check the capacitors with a capacitance meter, although when they are faulty they often physically look "cooked", leaking or feel really lightweight and empty. Replace them anyway if you think they are suspect.
  4. check any power resistors or attenuators. They will need to be replaced if not at their marked resistance
Good Luck. happy to go further if you cant get it working. If this gives you enough to service your crossover then rate me"fixya" Thanks
Posted on Jan 30, 2008
Ariston Troubleshooting
follow this test and use the multimeter and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating element(s) and replace if faulty
.Test and replace a heating element:
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Oct 27, 2013 | Water Heaters
7915 schematic
You are not likely to find one unless you deal directly with the manufacturer. Authorized repair shops spend thousands of dollars here in Canada obtaining schematics and prepackaged parts for known problem types with detailed oscilloscope tests to figure out which parts kit to use. If a device is too cheap to release schematics then it is just up to electronic repair shops who use their problem solving skills through thorough understanding of electronics. Those are the type of shops i learned at.
Oct 23, 2013 | Behringer FBQ6200 Home Equalizer
I have just bought a technics sc-dv290 hi-fi off of my cousin and found out the mid range and the tweeters have blown does anyone know where i could get replacent tweeters and mid-range speakers for it if...
As you probably know, these are the individual model numbers:
SC-DV290 the base unit
SB-DV290 speaker set
Front SB-DV290
Center SB-PC95
Surround SB-PS95
I'd scour Google or eBay for any or all of those models. Orphan speakers appear periodically.
Feb 10, 2011 | Technics SC-DV290 System
I have a Reliance 501 electric water heater. There are two panels. In the top panel is a red "reset" button. On two occasions this button has popped and turned off the unit. I have pushed the...
ECO reset button trips when thermostat senses high heat event over 150 degrees F, or when upper or lower thermostat is defective. There are other causes: if tank access covers and insulation are missing, and when element is shorted to ground in center of element so that element continues heating through one leg of 240V circuit after thermostat turns off.
Ordinary tank-type electric water heater is fully repairable by homeowner using generic parts from hardware store or home center.
1) Replace upper and lower thermostat for about $28, and if problem persists, then do troubleshoot shown in step 2 below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Take 30 minutes and troubleshoot before replacing any parts.
Troubleshoot requires cheap multimeter from home center.
Install battery in multimeter.
When testing voltage, rotate multimeter dial to 240 or 250 or 277 VAC.
When testing continuity or elements, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jan 13, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Rheem Electric water heater Model#71-52DB. It has no power and not heating when it does have power.
You need to troubleshoot water heater and electric going to water heater.
Troubleshoot takes about 45 minutes.
Typical electric water heater tank is fully repairable by homeowner using generic parts from home center or hardware.
Links below walk you through the steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Buy $5 multimeter from Lowes or Home Depot or Ace:
Image of Multimeter
Jan 12, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How to hookup ipod to technics sb-2840 speakers
quick solution is to go down to radio shack and get a small amp.  They have them for under a $100.00 bucks. The connection is from the mini jack to stereo RCA's for greatest ease and flexibility.  You can also go to a good music shop like Guitar Center and see what they have used.
Aug 03, 2009 | Technics SA-AX720 Receiver
Need service manual or schematic for SP PWA 10
http://www.fixya.com/support/p183860-jvc_th_a10_system/manual-17024/page-70
got there choose the right manuel for you i think you can download it you might need this software to read it www.adobe.com get adobe acrobat reader
Jan 18, 2008 | JVC TH-A10 System
How do I test an 8-0hm speaker or horn with a digital multimeter? Help!
What? You can take a friggin multimeter, stick it across the terminals and if it does nott give you any resistance back you fryed the voice coil. If you get 0 ohms it means you fired the voice coil. If you get 4, 8, 16 ohms then your good to go.
Jun 22, 2007 | KEF Audio Cresta 2 Speaker
457 people viewed this question
 Grubhead
Grubhead
