Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wiring the opener and sensors
I want to install a sears garage door opener but dont know how to wire the opener for the wall mounted pad and sensors
  • 118 Answers
The wall button gets the red and white wire. The safety eyes use the black and white wires. There are two types of attachments on the back of the openers. One has three screws. On this type the 1 is for the red wire, the 2 is for all white wires, and the 3 is for all black wires. The other type has four blocks and you just match the color to the wire color.
Posted on Jan 30, 2009
Hi, Working with a Sears 1/2 HP garage door opener that can be activated by a wall button or remotes. No key pad. About a year ago, I replaced the old motor, since it only turned in one direction. I...
The opener will not work without the sensors. Make sure you don't have a broken wire going to the sensors. Make sure the small light on each sensor is lit and not flickering. If you cannot get both lights to come on you have either a bad sensor or a wiring problem. If the main light flashes 10 times it is definitely a door sensor problem. The wall control may be bad now from usage. Remove it from the wall and short across the 2 wires. If that causes the door to try to move you then know the button is bad. You can also short across terminals #1 and #2. That would eliminate bad wiring to the wall control. Make sure the connections on the back of the motor unit are tight and that the 2 white wires from the sensors go to terminal #2 and the white wires with black stripes go to terminal #3.
Mar 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman Liftmaster will close using the wall keypad, but it won't open unless you hold the keypad down until it gets to the top. Then, the light blinks for about 5 seconds. I've checked the wiring and...
You may have a broken door spring or a bad drive gear. Remove the cover from the motor unit and check the condition of the gear. It may be stripped. Also make sure the small light on each door sensor is lit and not flickering.
Jul 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
We had a 1/2 horse opener with the model # 41A5021-3C in our garage .I put up another opener 41A3621 .Would like to know the wiring for the sensors and wall switch openers..The courtesy light comes on and...
The wiring should be.
Terminal #1 - White wire with red tracer from wall control.
Terminal #2 - White wire from wall control and a white wire from each of the sensors.
Terminal #3 - A white wire with black tracer from each of the sensors.
Apr 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door keeps opening automatically after code change
Changing the code on your keypad wouldn't cause this problem. It is most likely a bad wall control or the wiring going to it. You can eliminate both possibilities by removing the wire from terminal #1 on the rear of the motor unit. I would do that for a night or two just to see. You can then go further to eliminate the wiring or the wall control. If you replace the wire on terminal #1 and then remove the wires from the back of the wall control you will see if it is the wiring. The staples used during installation sometimes cuts through the insulation and cause this problem. The wall control just goes bad.
Sep 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
I DONT REMMEMBER HOW TO SET UP MY GARAGE DOOR OPENERS SENSORS ?
You have to match the codes of the garage door you're trying to open.
Aug 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
276 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
