Question about Vacuums
Eureka the boss the brush wont go around
A rug go caught in the brush and I pulled it out. it moves freely by hand but wont go around to clean the carpet. is there a rest button i dont know about?
  • scrappy13 Jan 29, 2008
    A rug got caught in the brush and I pulled it out. it moves freely by hand but wont go around to clean the carpet. is there a rest button i dont know about?
    Sergeant:
  • 201 Answers
Hey there scrappy13, I would suggest you unplug the unit, turn it upside down and remove the bottom plate uncovering the brush assembly. Inside there should be a belt which drives the spinner brush. If that is in tact, then the brush itself may have been unseated when you pulled the rug out. It should be obvious to find the correct placement. Reseat, ensuring the belt is attached properly to the motor as well as the brush. If the belt has broken, a replacement is available at a registered repair facility. Good Luck!
Posted on Jan 29, 2008
Vacuum turns on but the brush is not rotating
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Sep 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How to remove the eureka the boss super lite filter
Push up on the black slide button just above the dump cup and hold. With your other hand remove the dump cup. Once you have the dump cup removed, pull up on the rubber section of the filter to remove and clean the filter.
Feb 13, 2010 | Eureka Boss Superbroom Bagless VacuumStick...
The boss keeps shutting off
take the brush roller completely out of the vacuum then plug it in .you should be able to hold on to the ends of the brush roller and turn the brush freely if not the brushroller is froze.try taking the ends off the brush roller an see if you have carpet strands or hair built up around the spindles
Mar 22, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka altima stopped power mid vaccuming, have changed outlits
make sure all your filters are clean,try to turn the brush roller by hand a few times if it turns real freely then the belt is broke.if it is reall hard to turn then you have something wrapped around the ends of the roller where the bearings are.your motor guard might be keeping it from running because it got too hot take the brush roller out and the belt let it cool down for 20 minutes then try it without the roller and belt.you should be able to take the ends of the roller off by just pulling out on them so you can remove what ever is in there
Mar 21, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Drive belt ; whirlewind litespeed.
There is nothing but the motor shaft. The belt rides on the shaft and around the brush assembly on the other end. The belts fail if the brush assembly gets jammed, for example from a rug ot debris. If this occurs you should immediately turn off the unit,unplug the power cord, and clear the jam. Also occasionally cleaning the brush and being sure the bearings on each end turn freely will help prolong belt life. The brush assemblies also look to be available. lysager@gmail.com
Jan 25, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
No Suction
is your brush roller turning? unplug the vacuum and see if you can turn the brushroller by hand.if it turns real freely the the belt is broke ,if its real hard to turn then something is caught up around the bearings on the ends of the roller.my suggestion is if your having that much trouble withit take it back and tell them you want a new one.if they want to keep your buisness they will give you a new one
Jan 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
The brush roll on my Eureka Bagless The Boss 4 dimension cleaning vaccum itsn't working. How do I fix it?
Take either the plate over the brush roll off, if it doesn't come off, then the top cover comes off, should be 2 or 3 screws on the top to remove. Then you can get to the belt and brush roll. Check the brush roll, make sure the ends turn freely, if not replace it. The belt is either broke or stretched to the point that it won't turn the roll, replace it.
Jul 13, 2008 | Eureka Vacuums
Vacuums Logo
148 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
