Question about Refrigerators
Air condioner my Panasonic air conditioner(cw-xc122vu)won't shut off.
  • 236 Answers
Try the "on" and "off" button at the unit control if it wont work then your unit control is defective and need a replacement, But if it works then your remote control itself need a replacement.air condioner - 4054171.jpg
Posted on Jan 29, 2008
Hi, I want to know the meaning of the error code of an air conditioner panasonic s91 inverter.Grazie
Grazie, your question is rather confusing, because you listed to different model numbers for to different types of appliances. The "panasonic s91 inverter" is a cooking appliance. Whereas, the CW-X-C243HU is an air conditioner. So, which appliance are you inquiring about? And you didn't even say what the Error Code is.
Perhaps you can be bit more specific.
Jul 13, 2011 | Panasonic CW-XC243HU Air Conditioner
Compressor shuts off to soon . panosonic model cw1406bu
check for the run capacitor and the current of the machine.
Jul 25, 2010 | Panasonic CW-1406BU Air Conditioner
My window type aircon compressor run for 5 min,then stop for 4min,then run again for only 5 min even if the thermostat is set to the coolest setting and the the room temperature is higher than 30deg.C.it...
I have the same problem w/my CW-XC122VU. Other symptom is that the thermostat setting does not work in this "poltergeist" mode. After the problem went away by itself, then re-occurred, I notice it tracks the level of the water in the pan. A full pan of water will trigger poltergeist-mode, so I suspect some control or sensor is being shorted. The posted solutions ("transformer hum" or "broken on/off switch" are off the mark and generally unhelpful). We are not alone, though...the problem is observed in many Panasonic and Quasar window A/C units.
May 18, 2010 | Panasonic Heating & Cooling
Panasonic air conditioner issues
does it freeze up? this could be a sign of low freon. does the fan turn on? if not the compressor will get hot and shut itself down on overload the fan can be easily replaced for around 100.00
Oct 08, 2009 | Panasonic CW-XC243HU Air Conditioner
How to determine horse power of air conditioner
air conditioning units are measured in btu's stands for
(British thermal units)
6,000 BTUh to 10,000 BTUh will cool 400 sq.ft approximately
10,000 BTUh to 16,000 BTUh. will cool about 800 sq.ft approximately
16,000 to 28,000 BTUh will cool 2,000 sq.ft approximately
the idea is more but's the more cooling power it will have.
Aug 20, 2009 | Panasonic CW-XC203EU Air Conditioner
My panasonic in wall air conditioner doesn't cool anymore --
Hi, if your 6 year old Aircon has not yet been re-charged eversince it was bought, then yes it's time for a refrigerant re-charge.
I hope it helps.
Jun 01, 2009 | Panasonic CW-XC243HU Air Conditioner
How to clean my panasonic reveres cycle air condioners
here's a link for the insatllation operation maintenance manual:
http://ph.diplodocs.com/jim/PANASONIC/CWC60RU-_E
don't worry the manual is in english.
May 19, 2009 | Panasonic CW-C60RU Air Conditioner
HOW DO I SLIDE OUT THE CHASIS FRON THE CABINET?
First take out the front cover, you can pull it easily holding on to the drain pan. Pull-up and then pull out.
May 06, 2009 | Panasonic CW-C100AU Air Conditioner
Panasonic 1200btu air conditioner
you must check the fuse of pc board.its a glass fuse and propably had burned,replace it,if the fuse is ok then is the varistor and you must get an expert to fix it.
Oct 01, 2008 | Panasonic CW-C60RU Air Conditioner
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
