Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet GEW9250 Dryer; Only Running in Delicate Cycle
Just purchased a Duet dryer from a friend who's moving (it's two years old). The dryer works fine but I can't get the large cycle knob to work on any cycle but "delicate". The "delicate" light is flashing. I called Whirlpool and, after trying to "clear" the system by unplugging for a period and also pushing the "pause cancel" button twice, the problem remains. Anyone have the same issue and have suggestions? Thanks much!
  • 1 more comment
  • ARRGGH Jan 29, 2008
    Thanks for the reply. Is there no way of opening up and checking out the cycle control switch to see if it can be repaired without replacing the whole thing? If I need to replace it, what's the easiest way of getting the part number? Thanks.
  • ARRGGH Jan 30, 2008
    Do you mean replacing the "control board" or the user interface "control panel"?
    Should I replace the "control board" or the user interface "control panel"? Thanks.
    Genius:
  • 1,067 Answers
Control board u got it
Posted on Jan 30, 2008
    Sergeant:
  • 226 Answers
I suggest that you replace the whole part of the knob. It is called CYCLE KNOB.
Posted on Jan 29, 2008
  • 871 Answers
Hi you can actually open that with a few screw drivers and stuff, the problem comes in where you need to identify the part and from there you will need to find a replacement of that specific part.
however, if you ask some service shops about the control switch part, they might actually have this.
hope this helps.
  • 146 Answers
That knob is actually a switch. fixing it will be much easier, if you replace the whole switch unit..
good luck..
My Whirlpool Duet dryer has the "Control Locked"
Hi
To unlock it press the END OF CYCLE SIGNAL button for 15 seconds and the unit will reset.
Dec 31, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
How do you get the control lock off? my dryer will not start
TO DISABLE: Press and hold the END OF CYCLE SIGNAL button for
3 seconds.
When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
The manual can be found here.
Jul 07, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer
make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Feb 17, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer not heating
The first thing to do would be to check if the element is broken. Most dryers have a couple of screws that hold the top, and it opens like the hood of a car. The next step is to remove the drum, usually a couple of screws holding the front.
Jul 20, 2008 | Whirlpool GEW9250 Electric Dryer
could be a tub roller or idler pulley that needs to be replaced
May 16, 2008 | Whirlpool GEW9250 Electric Dryer
im going to try to help you for free did you not get the tech sheet when you changed out the control board
Feb 15, 2008 | Whirlpool GEW9250 Electric Dryer
more than likely a short in the user interface
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
3 1/2 year old Whirlpool Duet Dryer stopped heating up
it could be several things but the element could should be the last part i would check first if you are still using fuses change them both if that doesnt work call for service call a good service man stay away from major companies they are expensive i know i worked for most of them
Nov 22, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
175 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
