Question about LG DLE2532W Electric Dryer
Replacing blower wheel
Now that i have diagnosed that i have to replace blower wheel and i have the front off of the dryer, can anyone tell me how to hold the shaft still while I turn off the nut holding the wheel in place. I am using a 13 mm socket & wrench and trying to hold the shaft with vice grips but can't budge the nut or the whole thing slips. I am hoping I do not have to remove the whole assembly to replace this plastic fan.
Make sure you turn the nut clockwise to loosen it.
(backward threading)
Posted on Jan 29, 2008
This dryer does not have drum glides or pads, correct? But has the slide ring? Trying to diagnose noise.
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Jan 31, 2016 | Dryers
Hoover condenser dryer, drum is stiking, if i manually spin the drum ir will go bk in cycle
see this causes and fix it. God bless you
Not all will apply to every dryer. Check our video page for more style dryers.
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassemble the dryer to check these. Some dryers use rollers in both the front and rear. Check our videos for other style dryers.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace the Belt along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace the glides and bearing housing if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace the rear bearing when they're worn. Put hand inside drum near rear and push up there should be no play. This video walks thru another type.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace the blower wheel. Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace the motor.
Oct 02, 2012 | Dryers
I have a kenmore 70 series electric dryer that squeals or squeaks when you start it and will squeak periodically during the drying cycle. From what I can tell the actual model number is 66702692 or 110...
hello there and welcome to fixya
There is several areas that you will want to check and listen to it carefully
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Oct 01, 2011 | Kenmore Dryers
I have a maytag heavy duty gas dryer model number LDG412 i need to know how to clean the vent all the way to the duct, the dryer is getting hot but it is taking a long time to dry clothes now, inside where...
while cleaning the venting is never a bad idea and i recommend its done yearly,a common problem with older (the ldg 412 is from the mid 1980's) Maytag dryers isa stripped drive hub on the blower wheel and absolutly no air is being circulated throughout the dryer. A lot of times when starting the dryer and when it stops a rumbling noise will be made if the blower wheel is the problem. To check it if is the blower wheel you can remove the front panel by removing the screws that are a slight angle at the bottom of the front panel,tilt it out toward you at about a 45degree angle,then off. At that point remove the four 5/16" hexhead screws holding on the front drum support,lift it up slighly then off. The blower wheel will be in the lower left corner and you could spin it by your hand if it spins around the motor shaft it slips onto and does not move the drum while turning the blower wheel,it is stripped and needs to be replaced.To replace it remove the 1/4" hex head screws that hold the front plate to the plastic blower housing(7 screws) and the 5/16" hex head in the tab also in the plate in the front of blower housing the plate where come off. To replace blower wheel remove the greenish/black clamp from the center hub and the thin metal ring that fits ina groove on the motor shaft, a special c/e clip ring pliers are needs to remove the ring. A inexpensive pair could be picked up at most places that sell tools(ace hardware/lowes/home depot/sears) The part number for the blower wheel is 303836 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
I hope this will help you to repair your dryer,
Gene
Aug 07, 2011 | Dryers
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
http://www.repairclinic.com/SSPartDetail.aspx?s=t-pdet920ayw-%3d%3di966673&PartID=966673
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 27, 2009 | Maytag Dryers
Dryer squeal @ start up; access
It sounds as if you have a dry rear drum roller. Check the above link first for parts and teardown.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
Blower wheel on dryer is loose
Jclay, you are in for a little work here partner. On this model the blower is up-front. The dryer is going to have to come apart for you to tighten or replace the blower wheel. The end caps on the consol will pull off. Remove the two screws on each end securing the consol. Flip the consol up. There will be 3 quarter inch screws under the consol, in back, holding the top on. Remove these and the top will slide off, forward. Remove the bottom panel by the blower. Remove the lint filter. Remove the 4 screws attaching the front panel and door to the front of the dryer, remember to unplug the door switch cable. The drum now can be removed after removing the belt. Take the tension off the belt by moving the pulley over. Remember the belt configuration so you can put it back on right. Once the drum is removed you will now be able to get a wrench on the motor shaft itself so you can tighten or replace the wheel. Reverse the above steps and your back in business. Im going to attach a picture of a rear blower system and the way to take it off. Yours is up front but the removal will work the same way. Sometimes you have to cut the old blower wheel off because it's fused on with heat. Your part number for the wheel is 697772. Remember to unplug the dryer during this work..Catriver..post back.
Aug 30, 2006 | Kenmore 63012 Electric Dryer
LG DLE2532W Electric Dryer Logo
193 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
