You have to wind up the spring before installing the cord. Look which way the spring goes, wind it up tight, back off enough to insert the cord through the hole in the outside housing, tie a knot inside the inner pulley. Slowly let the spring recoil while allowing the cord to go in. Cut the cord to the proper length, put the end thru the handle, knot it and attach the assembly back to the mower.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
There is a spring inside the pull cord housing that makes the cord come back in, it probably undid itself, remove the housing cover and rope assembly and you will see the spring, you need to retighten it and place everything back. hope this helps
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
