Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
BLANK SCREEN, NO IMAGE, LINES ON SCREEN, VIDEO CUTS IN AND OUT
The problem is a bad CCD inside the camera. I have 3 bad ones in my classroom. Sony was providing free service for some of their other models but failed to provide service (recall) on these models. I think it is important to contact Sony at 1-866-703-7669 and ask them why they are not providing support for this model since it has to do with a bad chip inside the camera. Sony should stand behind their consumer products and keep in mind that some people who use the consumer brands also use or recommend the professional brands to organizations like WEVA and others. If they do not support the consumer line products, will they support the more expensive industrial or professional products? Let's go Sony...fix these problems...there are too many of these cameras which have gone bad to say that it is not a CCD problem.
  • d5wstat Jun 04, 2008
    I agree. I called Sony with the same problem and they tried to sell me on the $211 flat rate repair. They claim that the CCD in this unit is not one that requires replacement because of the recall.
    Depending on how this turns out this may be my last Sony Cam.
  • 3 Answers
I have the same problem. Sony wasn't helpful. They recommended the $211 flat rate repair fee. They did not own up to a problem with this model. From what I'm reading on the 'net it seems to somewhat common.
Posted on Jun 04, 2008
    President:
  • 4,402 Answers
Jvc and others have the same problem,...
Posted on Jan 29, 2008
Blank screen no image in camera mode is it an image sensor and can it be fixed
Mostly. image sensor causes the blank screen, but especially the Iris is the problem in this model.
Example:
Sony CCD TRV68
Oct 17, 2014 | Sony Handycam DCR-TRV27 Mini DV Digital...
Sony cybersoft DSCW350 screen is white when I switch it ON and it is blinking all the time
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 13, 2012 | Sony Cybershot DSCW350 Digital Camera
Dsc-s730 camera . The subject appears very dim/purple when I take a shot. Picture appears same on lcd or pc. My lcd/ribbon cable must be faulty .? I can view old pictures on lcd screen perfectly .
a CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
Jun 09, 2011 | Sony Cyber-shot DSC-S730 Digital Camera
Lines across the picture on screen after picture taken.
CCD (Charge Coupled Device): one of the two main types of image sensors used in digital cameras.
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card. A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image).
If seen on both your pc monitor as well as the camera's LCD then it's likely a CCD issue and it's no wonder that it will be more expensive than buying a new digicam. This is why you need to be exceptionally careful when taking care of your camera since most are uber sensitive to being damaged by the slightest miss-handling.
Hope helps.
May 29, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
Screen shows blurry vertical lines instead of image
It is failure of ccd imager chip in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 20, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen went dead
Jan 27, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Video screen has horizontal stripes when viewed
Jan 21, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Noisy operation, picture flickers in record and play back. Auto exposure problem? Like camera is trying to fix apeture to compensate for light.
Dec 08, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
DC400 Screen only showing slanted multicolorlines
No this is clearly a CCD sensor problem ( CCD generates image in v-cams and still digital cameras ) if the sensor is outputting too much noise then your image will be distorted just like yours is. If the sensor is outputting nothing then camera shows blank screen ( also notice that with this problem you can playback OK ). Replace CCD block.
Sep 06, 2007 | Audiovox DC400 Camcorder
Problem with Sony Handycam
ccd image sensor of your camera is already damage...go to the sony service center for replacing the ccd...the model of your camera is one of the recall products due to the factory error of the ccd image sensor production...
Feb 07, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
