Question about GE PSI23MGN Side by Side Refrigerator
Slow leak in refrig. coolant tubes.
My model has a hard plastic coolant unit behind the vegetable and meat bins. Water circualtes through this unit. Water has been dripping down into the lowest drawer and causing an unsanitary mess.
I think I have traced the problem to a seam in the coolant unit. I applied a PC-Plumbing compound to the entire seal. This product has to be kneaded to mix and will only adhere to this plastic if the plastic is damp. I am waiting for this to cure before I know if it is fixed. Fortunately the coolant unit is not visible so the compound is not showing.
  • Anonymous Jan 29, 2008
    I have the same leak problem. Did your solution work.
    How can I contact Daewoo to get them to fix it?
    Kind regards
    James
  • 62 Answers
If that doesn't work go to an appliance repair parts store or HD buy about 10 ft of plastic tubing coil up and use it to replace the tank. Alot of the newer models use this instead of a tank.
Posted on Feb 16, 2010
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Water is collecting beneath the vegetable and meat bins whirpool model number et1chkxkb03 assistance will be apptreciated
The drain is clogged. remove freezer floor by removing screws in floor...pull forward. its possible you may need to remove rear panel...a few screws and off it comes. open up the ice thats frozen in the trough and open drain tube...
Feb 16, 2011 | Whirlpool Refrigerators
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
defrost it, remove back panel on freezer side, and unclog small hole where water collects
Feb 13, 2010 | Refrigerators
Water under the vegetable and fruit bins in refrigerator. Model number TBX190ABBRAA. Read that is could be a clogged defrost drain tube, and I do not see a drain pan. Would like to fix myself without...
the compressor is sitting in the drain pan
the defrost tube is behind the freezer rear wall
the best way to fix this is to shut the unit off and let it defrost
Oct 09, 2009 | Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Model #ed5lvaxvqoo; ice maker quite working, no water WHIRLPOOL
Due to your refrig having the ice bin on the door , it could be a little bit more difficult to diagnose . Pour about 1/2 cup of water into the icemaker . If it doesn't dump , then the problem is the icemaker . When you open the freezer door , does the laser lite flash 2 times then pause then 2 times etc.? If the lite does not flash , it means the icemaker is in the harvest mode (dumping) . If stuck in the harvest mode , replace the icemaker . If the icemaker dumps the frozen cubes , then the black fill tube above the fill cup , could be frozen , or the water inlet valve is bad . If you feel ice in the black tube ,(water valve bad due to slow drop leak ) you'll need to pull the fridge from the wall , and see if there is a plastic coupling on the tube going up to the icemaker . If not , you should get one in case of future problems . Cut the tube (or disconnect the fitting ) (if you can blow thru it , black tube is not stopped up with ice ) and turn the icemaker off . Turn the freezer setting down a number or two . Go by ocassionally to see if you can blow thru the line . This water line goes between the top of refrig and the inner liner . Bad design because if it freezes , no way to get to it . Can try hair dryer2.gif on top of refrig . I have known it to take several days for this line to thaw .
Aug 28, 2009 | Whirlpool Refrigerators
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Sub-Zero 550 water leak and freezing
Seems to be a common problem with these units. You can get a drain tube heater ( got mine from an online refrigerator parts distributor), though may not totally solve problem. Some suggest running a copper wire through tube - supposed to conduct just enough heat to keep tube from freezing.
Sep 05, 2007 | Sub-Zero 650 / O Bottom Freezer...
GE PSI23MGN Side by Side Refrigerator Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
