Incoming messages on answer phone muted?
Please help.
Can this machine be set to mute all incoming messages on answerphone? Confidential messages can be heard by anyone in the room.
Thank you.
    Genius:
  • 1,003 Answers
IT SEEMS THAT YOU COULD SIMPLY ADJUST THE VOLUME TO A VERY LOW SETTING to remedy this problem
Posted on Feb 02, 2008
Incoming calls
Check if the phone is on mute.
Jun 24, 2014 | Alcatel One Touch 990s
How do i mute incoming call on samsung s7220
Hello Sir In Idle mode, press and hold # to silence or unsilence your phone.
And To change Your Ringtone follow these steps ! Change your ringtone Phone ? Settings 1. In Menu mode, select profiles . 2. Scroll to the profile you are using. > Voice call ringtone ? Edit
May 05, 2011 | Samsung Cell Phones
. Base unit Answer on
Lighted button you see may not be for ANSWER SYSTEM. Lights on Base units may indicate INCOMING MESSAGE already stored or all sorts of system ready lights.
Please do these three steps:
1. From the handset, Go to menu and set ANSWER system to ON once more
2. In the menu, set the number of incoming rings before ANSWER system turns on, to just 2.
3. In the menu, record a new message using your own voice.
then, Dial your own phone number from a cell phone to test.
Watch/listen as the incoming message is played. repeat any of the above if the system doesn't work.
Post a new question and include the model number and manufacturer of your system.
I work for a manufacturer of these machines and I can help.
S
Feb 22, 2011 | Cell Phones
How do you answer a call on a BB 7290?
This is the instructions in making callsand answering calls and how to mute a call. Making Calls Input the desired phone number into thekeypad, then press the "Enter" button to initiate the call. Press the"Escape" button on the right side of the device to end the call. Tap"Answer" to answer a call or "Ignore" to reject an incomingcall. If you are on a call, tap "Answer --- Drop Current" to end acurrent call and answer an incoming one or "Answer --- Hold Current"to place the current call on hold and answer the incoming one. Press the"Phone" button to mute a call.
Jan 08, 2011 | RIM BlackBerry 7290
When testing the outgoing message the volume seems
http://www2.bt.com/static/i/media/pdf/response_75_userguide.pdf
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Dec 10, 2009 | British Telecom Response 75 Digital...
Ringer does not work on incoming calls
If someone is calling, do you see it on the phone? If so, you may have muted the sound. Try looking for a a button with a music note on the phone. Hold that button for a bit(atleast that's how it works on my phone)
Feb 24, 2009 | Uniden 2.4 GHz Expandable Phone System...
No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Nov 08, 2008 | Samsung SGH-D900 Cellular Phone
Please help
No unless there is a switch to adjust the volume turn that right down if nopt no you can't do that
Hope this helps - Josh Howard
Jan 29, 2008 | Office Equipment & Supplies
88 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
