Question about LG DLE2514 Electric Dryer
IT READS tEl in the timing area
Where the dryer running time is posted it continuosly reads the letters tEland when you push the power button it starts beeping and the check filter light comes on. I have checked the filter and its clean please let me know what these letters mean and how i can fix them
  • 489 Answers
TEI means that the thermistor has failed and needs to be replaced.  The filter light always comes on as reminder to check the filter before starting.  That cannot be changed.
Posted on Apr 28, 2008
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Tempo 621T treadmill incline Incline reads 0.0 but is not all the way down. How to bring it down.
you must RUN the software calibration, for troubleshooting and fix it.
See the steps.
The Steps fhor Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
    1. F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
The link on FixYa to the HB65R Intermatic timer Manual seems to be broken. Do you still have it?
Fixya does not have HB65 manual posted.
Open following link to identify timer and download manual in English.
If this is not your timer, add a comment with clear description of timer, or in-focus photo of timer posted on flicker, so I can locate possible manual.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#HB65R
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Jul 19, 2011 | Garden
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
Intermatic hb65r residual outdoor timer
Here is the instruction manual for your model:
HB65R Timer
Hope this helps!
Also consult this website for sunrise, sunset information for your area:
Sunrise sunset calendar
Dec 05, 2008 | Hardware & Accessories
Kenmore Dryer fuses
don't worry about the thermostats they wont stop the drier from running set your meter to continuity should have a wave symbol on it touch the leads of the meter together to make sure its working should read zero then touch the leads to each end of the component and if it reads ol or open its bad any time you take a component reading you must make sure at least one side of the component is unplugged to prevent getting a false reading
Mar 02, 2008 | Kenmore 62602 Electric Dryer
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
LG DLE2514 Electric Dryer Logo
150 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
