Question about Dryers
DRYER PROBLEM DRUM AINT TURNING, DRYER MAKING SAME SOUND AS IT DOES IF FILTER CARE IS NEEDED
  • Anonymous Feb 16, 2008
    belt is not functioning, need to change or repair
  • 4 Answers
Your belt is broke
Posted on Feb 02, 2008
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Why is the dryer making a squilling sound
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Aug 18, 2014 | Kenmore Elite He5T Dryer Heating Element...
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
Dryer works, but makes noise.
There are a lot of moving part that can cause noises or vibration when get worn out.
  • Make sure dryer is level, and on a secure floor, and that nothing is leaning against the dryer.
  • Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
  • Check for foreign objects below the lint filter:-Remove lint filter, and look down opening. If you need to stick your hand down the opening to remove an object, be careful because the edges could be sharp. It would be advisable for you to wear a pair of work gloves.
  • Foreign objects in the drum front seal and worn or loose drum slides can cause a metal scraping noise as the drum rotates.
  • Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
  • A frayed or damaged belt will make a thumping sound.
It is normal to hear the sound of the drum as it turns. If your dryer is making unusual noises and the above suggestions do not resolve the situation, discontinue use of the dryer until it has been checked by a qualified servicer. Continued use may cause wear of other parts making the repair more costly.
Thanks..!!
Sep 19, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Won't spin or start
Sounds like the screen/sock combo got the tub in a bind and the drum belt broke.
If you want to pursue replacing the belt, let me know.
Apr 30, 2009 | Amana LGA10 Dryer
Scraping sound when tub is rotating.
The motor turning the drum may be bad OR the spindle or axle the drum turns on may be bad as well. The belt turning the drum may have been to tight thus putting too much pressure on the drum which eventually would wear it out then causing the noise which will only get louder as time goes on.
You will need to take off the back of the dryer and possibly the top to gain proper access to the drum and motor.
Jan 14, 2009 | Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
