Question about Toshiba 55H70 55" Rear Projection Television
Pic distorted slightly on left side. news (crawl) on bottom of screen angles down on left side, top of pic seems to angle up also. very minor problem but annoying anyway! pic clarity & color excellent.
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Posted on Jan 29, 2008
How to put in sim card
Assuming you mean the 2013 version but I'll try both,
so for the 2013 version
  1. Turn your tablet off and place it on a flat surface with the screen facing up.
  2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
  3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
  4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
  5. Push the tray it gently back into the tablet.
  6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
Activate SIM card
  1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
  2. Swipe down the notification shade and touch the notification.
  3. Follow the activation instructions provided by your carrier.
For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
*Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Bought a 2002 GMC Yukon that seems to be well maintained and runs well. it was hit in the left rear quarter lightly and it seems the load leveling system is maxed out because the back of the truck seems...
Have a shop that makes tail shafts check the operating angles of the u-joints and the diff pinion angle. What looks minor camage may hide significant under carriage damage that alters the angles of the diff pinion and alignment with the rear of the transmission.
Dec 09, 2013 | 2000 Ford Expedition
Whereiscraqnksensor
The crank angle sensor is located on the top of the transmission bellhousing, mounting bolt is a 10mm bolt, bottom left side (if you are looking at the engine with the intake on the right) and is very hard to see.
CAUTION: Do not apply much force on removal or installation of the sensor bolt as its bracket is very fragile. If the bracket gets distorted it could cause a no-start condition as the AC sine is too weak to be detected by the ignition computer. Also, work on the system powered down. Remove that battery negative cable!
Jul 31, 2013 | Volvo 940 Cars & Trucks
Bottom of screen is projecting at an angle. Other 3 sides are at 90 degree angles
It is called as keystone distortion. To correct the problem press the "Keystone" button on the projector, then press left, right, down & up arrow buttons to adjust the angle at 90 degrees.
Aug 15, 2011 | Mitsubishi Office Equipment & Supplies
20" poulan chain saw cuts at angle
Hi
You must have hit a nail or stone with the one side of the chain. When the chain gets duller on one side than the other is what makes a saw cut at a angle. Get the chain sharpened and it should cut straight again.
Sam
Jan 08, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do I put new cartridge in
Follow this procedure to install print cartridges in you printer.
1 Turn on the HP Officejet, and then lift open the print-carriage access door.
The print carriage moves into view.
2 After the carriage stops moving, push down on the top of the print
cartridge to release it, and then pull it toward you out of its slot.
3 Remove the new print cartridge from its packaging and, being careful to
touch only the black plastic, gently remove the tape by using the pink pull tab.
Caution! Do not touch the gold-colored contacts or ink nozzles.
Once you have removed the plastic tape, install the print cartridge
immediately to prevent the ink from drying in the nozzles.
4 Hold the black or photo print cartridge with the HP label on top. Slide the print cartridge at a slight angle up into the right side of the print carriage.
Press firmly until the print cartridge snaps into place.
Caution! Do not attempt to push the cartridge straight into the slot.
It must slide in at a upward slight angle.
5 Hold the tri-color print cartridge with the HP label on top. Slide the print
cartridge at a slight angle into the left side of the print carriage.
It must slide in at a slight upward angle.
Note: You must install both print cartridges in order for your HP Officejet to work.
6 Close the print-carriage access door.
“Press OK to print Align page” appears on the display.
7 Press OK.
Oct 06, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Canon LBP 1120 Offset paper feed and subsequent jamming.
G'day, I pulled the whole printer down and gave it a clean and put it back together and set it to work. All good.
May 11, 2009 | Canon LBP 1120 Laser Printer
Plc-xu30
This is called "keystone adjustment". If you still have the owner's manual, it will describe how to do it. If you don't have the book, look on the button console on the projector, or on the remote for an icon that looks like a rectangle that is either narrow at the top or narrow at the bottom and press it. That will get you in the control. If there's no button, you will probably find it on the set up menu. It's pretty easy to do the adjustment, one way makes the image narrower at the top, the other makes it narrower at the bottom. Some older projectors just have a **** on the unit that changes the angle of one of the mirrors inside to accomplish the same thing. The reason for this adjustment is to compensate for the distortion of the image caused by a projector mounted near the ceiling and pointing down at the screen, or sitting near the floor and point up at the screen.
Mar 10, 2008 | Sanyo PLC XU30 Multimedia Projector
Hl-44266w screen allignment
Don't recommend replacing the light tunnel if you never had any experience with DLP optical systems. you need to pay careful attention to the way you remove any screws or you will be forced disassembling the engine multiple time to get the alignment correctly.
Jan 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Open to Clean Glass
This is a pain; MicroTek offers no instructions; proceed at your own risk, etc. Before you start, get some high-quality optics cleaning kit ready to go, and clean the outer glass perfectly, so you don't have to keep guessing whether remaining smudges are on the inside or out. Remove lid by simply lifting to 90 degree angle and then lifting upwards. Remove all cords, so lid is not connected anymore. You need a thick, strong paper clip. Unfold it so one part functions as a handle, leaving a short length suitable for poking into holes. Lock the chassis on your scanner (underside, coin in red button, turn to locked position). Now sit in chair in front of desk. Put scanner with buttons on your lap, glass towards you. Hold hinge side of scanner with left hand. Notice that there is a pin hole just to the outside of each hinge slot. Now comes the hard, you -might-break-something part. Use right hand to insert paper clip into rightmost hole. With left hand, put a fingernail in the gap where the lid is gonna come off. Press firmly (pretty darn hard, in my experience) with the paper clip to release the tab that holds the top in place while pulling with your fingernail. With luck, a slight pop and that side is done. Repeat on the other side. Note: don't let paper clip angle down towards bottom, slip past retaining tab, and poke into something vital. There is also a third clip dead center, but it seems to pop out with little effort. Unfortunately, you're still not done. There are two more clips about halfway down each side, and no visible way to depress them. You just have to lift up with a frightening amount of force until they make a big "pop" and hopefully don't break. Now the darn thing is still hooked at the front (where all the front panel buttons are). You want to kinda lift the back end up, jiggle, and then pull up and back (I busted one of my front hooks before I got it off). Now the top is still connected via a ribbon cable, but you can put the edge of the top into the lip of the bottom, hold the back of the top at a 90 degree angle, and clean that glass with your left hand. Get it perfect, because you don't want to have to be doing this again. I kept a very bright LED flashlight at hand so I could shine it at oblique angles to scan for smudges. Of course, your scanning element is more vulnerable to dust during this whole process, so try to do this in a relatively clean room, and try to get done quick without dumping any dust on the innards. Good luck, and join me in saying "I'll never buy another scanner that isn't designed to let me clean the inside glass!"
Apr 04, 2007 | Microtek ScanMaker 6100 Pro Flatbed...
Toshiba 55H70 55" Rear Projection Television Logo
114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
