Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9100lq1 when selecting the type of wash i want with the dial the red light keeps flashing. When i push the green start button and hold it the washer does not start. It continues to flash. I unplugged the machine and left it alone for a while. Tried it again and did not work. I think the door is not locking and that is why it is not continuing. Is that correct? Somebody help!!! Thanks.
  • 4 more comments
  • RDWASHER Jan 29, 2008
    i will try again.
    Thanks
  • RDWASHER Jan 30, 2008
    The shutting of the door did not work. I do not hear any clicks. I tried to do the startup procedure that is mentioned in the service manual. I press the control on button
    i select the drain/spin cycle
    select nospin by pressing the spin select button
    i push the rinse/hold button 4 times and c:00 should show on the display.
    I did not see any code. The light continues to blink and the time shows 0:02 minutes.
    I push the start button and then i hear clicks but nothing happens? any clue?
    Thanks
    pause cance twice clears the display
  • Brewtan Jun 15, 2008
    same model (HGW9100LQ) and have same problem. diagnostic test does not seem to apply to this. All lights and buttons seem to work but the main selection dial will switch fromm one selection to another but the light flashes continously at each.
  • Karl Whisenand
    Karl Whisenand May 11, 2010
    Do you hear six clicks during this time?
  • robert samples May 11, 2010
    its a possibility with front loaders you need to shut the door with a little force push pause cancel twice then open the door and close it firmly try it again
    President:
  • 1,314 Answers
Push pause cancel twice let me know if this clears the codes
Posted on Jan 30, 2008
  • robert samples Jan 30, 2008
    also if you pull the top off you will find a tech sheet with trouble shooting info see if you can find it and check the lock connector at the control panel and see if its getting a tight connection there
    ok shut the door firmly and try it again to see if it resets
    Genius:
  • 1,554 Answers
The official explanation is the door locks being bad the CCU computer being bad, the cables being loose. but it is usually a back solder job on the oboard.
see this discussion I am having with another as it applies to you also.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
6ya staff
SOURCE:
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    How to reset beko wm5120w washing machine
    You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
    Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
    What is the pairing security code for xx3 plantronics
    The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
    1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
    2 - Then you need to place the headset in pairing mode so your phone will find it.
    Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
    The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
    For the Plantronics M3000/M3500 (discontinued):
    Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
    For the Plantronics 510 Voyager:
    Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
    Plantronics Explorer 320,330,340 & 350
    Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
    Plantronics 655, 665
    Plantronics Discovery 640, 645, 640e
    Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
    Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
    pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
    pulsar_260_128.jpgPlantronics Pulsar 260
    For the Plantronics Pulsar 260, Begin with pendant powered on.
    Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
    indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
    enter 0000.
    For the Plantronics M2500 (discontinued):
    Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
    For the Plantronics M1000 (discontinued):
    Hit and hold the volume/mute switch in until the indication light starts blinking.
    For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
    For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
    You can also use the Plantronics Bluetooth Pairing Guide
    Feb 05, 2011 | Cell Phones
    I have a technika diswasher,not sure of the model, is approx 3 years old and has a big dial on the left hand side with 7 wash functuions and the power button is smaller and is on the RHS. I cant remember...
    I have the same model. You just turn the dial to the setting you want, push the dial back in, turn the (right) power button on then turn the smaller start button on. I use different cycles all of the time depending on whats in the load and this works fine for me.
    Apr 27, 2008 | Dishwashers
    The washer mode light keeps blinking
    the machine is locked out on the control, go to the signal button on the far right side and hold the button in for four seconds and it will unlock the control and yu can select the cycle that you want
    Apr 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Front Loader - whirlpool - does not star
    machine controls may be locked. Power on the unit and hold in the far right button for 4 seconds and then try to select settings and cycles
    Apr 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool dishwasher # quiet partner II
    Pushing and holding the 'Heated Dry' button should turn off the light over the padlock symbol and get you going again.
    Jan 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirlpool Duet GHW9150P Front Load Washer Logo
    521 people viewed this question
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
    jimorris77
