Question about Samsung Televison & Video
PS3 and Samsung LE37R88BD
Hi, I hope you can help. I'm having problems with my Samsung TV and PS3 working together. During gameplay, the screen keeps fading through black. This only happens when I use the HDMI cable.
I tried using the scart cable and the PS3 works fine, but the picture quality isn't great. I've used different HDMI cables and have the same problem. I even tried my PS3 on a 40" 1080i Samsung tv and the blinking still happens.
What is the problem do you think?
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
SOURCE: PS3 not working through HDMI cable
connect PS3 to TV select HDMI channel on TV press AND HOLD power button on PS3 until screen resolution selection page appears.
PS3 should now work.
had this problem, this solved it.
typical repairman looking for work :)
Posted on Jun 29, 2008
mistersony
  • 320 Answers
SOURCE: Sony 2006 40s2010
It very much depends on:
the model of DVD player you have and whether it is a standard or blu-ray player
the settings on the player
the type of connection (component and HDMI will yield a better picture)
Posted on Oct 19, 2008
opherator
  • 44 Answers
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Posted on Feb 27, 2009
DRebel
  • 19 Answers
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Posted on Apr 03, 2009
Hi, when i start my FIFA it loads my trophie collection, then i can choose which language i want. then there comes this screenie from Official licenced product, with Petr Cech in the background. but that...
The game is default to your PS3 Language as default in order to change the Language during gameplay you must change PS3's Language.
Hope this helps.
Apr 18, 2011 | FIFA 11 for PlayStation 3
During gameplay on my ps3 the screen goes black for a couple of seconds then resumes
This sounds like a problem with the hardware inside of your ps3. You may have to take it back to where you purchased it.
Mar 07, 2011 | Video Game Consoles & Games
Sometimes my ps3 freezes while loading also during gameplay and just in gameplay there are color streaks and glitches occur
This sounds like a problem with the HDD. If you have any save files you wish to back up, use the Backup Utility under the settings menu. Once you've done that, Format the PS3. If you are still experiencing problems you will need to contact Sony. Their number is 1-800-345-7669.
Jan 22, 2011 | Sony Playstation 3 (PS3) Console
Ps3 doesn't work propley with samsung hd tv
keep ypur finger on the off button for 20sec
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Code displayed over my ps3 xmb, affects gameplay
video rsx cpu maybe partially damaged..i can probably fix it.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
My ps3 after in hour of playing freezes and won't play
This is a common problem that can be one or two reasons. One is that your PS3 is overheating during gameplay and is shutting down or freezing. If this is the case you should make sure your ps3 is clean of dust and is in a well insulated area. Try investing in an external fan that will keep your system cool during gameplay.
Secondly you may have a problem with the laser reader. If this is the case you will need to have it repaired by sony. You may be covered under a warranty, so please contact sony to find out your options.
You can contact sony by calling the number listed on the back of almost all of your video game booklets.
Happy Gaming and Good luck to you.
Oct 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 controller issues
Have you charged the controllers in a while. The controler might just be running out of energy to work.
Apr 05, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
