Question about Bionaire Tower Compact Heater
Heater unit # BH3930-u
Remote do not work and unit will not change to automatic.
[email protected]
  • jstauff Jan 29, 2008
    your manual did not solve the problem.. The remote did not work since purchase. I wou ld like it replaced..I will forward th e o ld remote to y ou .
    Reply is rewqu ested.
    J. Stauff at shentel.net..
    Genius:
  • 3,422 Answers
Here is the manual for it:
Read it carefully ur problem will be solved..
http://www.bionaire.com/bionaire_US_manuals/BH3930.pdf
Goodluck,
Don't forget to rate me as fixya..
Posted on Jan 29, 2008
6ya staff
SOURCE:
Heater won't stay on, I heard there was a recall on this item.
Hi and welcome to FixYa, I am Kelly.
I am only answering part of your question (Recall) so do not rate the post so other experts can help you with your heater won't stay on problem.
Your heater model is not one of the 4 models that were recalled.
The recall involves Holmes® models HFH6498-U, HFH6500-U and HFH6500TG-U and Bionaire® model BFH3530-U. The recalled heaters also have date codes beginning with 2604 through 3804 for all units, except for Holmes® model 6500TG-U, which has date codes ranging from 2604 through 4704. The model and date code can be found on the silver label on the back of the unit. The heater fans are 26 inches tall; come in all gray, two-tone gray, or black and gray; and have either the word Holmes® or Bionaire® printed on the front of the base.
See this link for more details:
http://www.holmesheaterrecall.com/
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
I have the bionaire oil heater boh2513g. I placed a towel over it to dry and I think it's went into overheating safety mode because the three lights are flashing but the appliance wont come on. Is there...
Turn the Master switch to OFF and plug the heater and leave unplugged for 30 minutes, That should give it time to reset itself. If it doesn't work after that, it's probably fried.
Mar 15, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
Can't get heater to restart using remote control & 2 small green lights on heater flashing on & off
Have you tried replacing the batteries in the remote control? That may be part of the problem.
If you have already changed them, unplug the heater for 30 minutes to allow it to reset itself.
Hope that solves your problem.
Feb 28, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
I have the Bioaire Air Heater - BH3930-U. It is working but all of the lights on the front of the heater are blinking?
This is probably due to the fact that its in aux. mode. Can you tell me which lights are blinking?
Jan 27, 2011 | Bionaire Heating & Cooling
My heater will not react to the remote control. I
The manufacture did change remotes for some of the remote controlled units. You may have the older remote/receiver and need to replace it with the new verison. You can find the manufacturer online at www.desatech.com and find parts distributors.
Oct 20, 2009 | Desa International GWP30T Heater
Rinnai tankless water heater. gas will not ignite automatically . have to bleed gas screw on heater every time.
CHECK THE AMOUNT OF PRESSURE COMMING IN TO HOUSE, MIGHT HAVE TO CHANGE THE METER, OTHER GAS ITEMS IN THE HOUSE ARE STARVING THE UNIT AND TAKING FROM IT
Apr 14, 2009 | Rinnai Digital Remote Water Heater Control...
REMOTE CONTROL DOESNT WORK
Some of the remotes that originally came with those units did not work or last very long. The manufacturer then later offered another remote to replace the first units. It looks like the model number you provided is a serial number, not the actual model number. I suggest that you contact Master Parts at 800-446-1446 with your model number (you should be able to find it directly on your unit with the serial number you provided) and they should have that replacement available for purchase. You also can find them on-line at www.masterparts.net. I hope this helps you!
Oct 18, 2008 | Vanguard International Blue Flame - Medium...
Rainbow vaccum
Make sure the bowl has the pin on it. The Vacuum has switch in the bottom that keeps the Vacuum from running if the bowl in not on or the little pin is broken off.
Ralph Wakeman
[email protected]
Oct 18, 2007 | Rainbow 75th Anniversary Canister Vacuum
Heating & Cooling Logo
543 people viewed this question
Top Bionaire Heating & Cooling Experts
Richard McDermott
Level 1 Expert
Dennis Webber
Vernon Taylor
Are you a Bionaire Heating and Cooling Expert? Answer questions, earn points and help others
