Motherboard when i switch on my power supply the cpu fan turns on by it self with out me pressing the powwer botten. (nothing on screen)
  • 118 Answers
If you use ATX power supply
Follow these steps
Switch on the power supply
Hold the power button approximately for 10 Secs , your system will be switched off. Now switch on the power supply and press the power button to return normal operation.
Some times pressing reset button also solves the problem
If above procedure fails , please check for any loose end connections inside the cabinet. memory slots, any pci slots also check the battery .
Hope this would help
Best of luck
Posted on Jan 29, 2008
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
Jul 08, 2015 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
It was just this morning when I tried to turn my pc on.. unfortunately it did not. ! when i press the power button on cpu it turns on for a few second like one or two but immediately after it drops the...
Try replacing the power supply - I had a similar problem that was fixed that way. If that doesn't work, it's probably the motherboard itself. The CPU is also possible - have you overclocked it or otherwise cooked it? Is the CPU cooler/fan blocked with fluff, or has the fan been slow (or stopped) - noisy fan is a sign of bearing stiffness/partial seizure which slows the fan and lets the CPU get too hot. If the CPU is fried, you get the symptoms you describe (MB won't start the PS)
Dec 23, 2010 | ASUS M2N-MX Motherboard
No power on N1996 argon motherboard. Cpu fans
if it's switching its self off after about 10 second then Your CPU Chip is not right some how it could be / damaged / the wrong socket type for the board as alot of CPU's are very simmler / The CPU's (4 pin) power supply is not connected or the CPU hasent gone in to the socket properly when this happens it will power up but will send no power to the monitor, or somtimes set off an alarm that sounds like a sciron going off.
May 05, 2010 | HP Compaq Motherboard
Cant get computer to
Disconnect everything from the motherboard except the power supply, CPU and power switch.
Turn on the computer. You should hear 3 beeps because you removed the memory.
If you don't hear any beeps, check the power supply. Check all the connections. Did you connect the 4 pin power? Did you skimp on it? A common mistake is to get a cheap, high-power supply. Just because the box says it's 1000 WATTs doesn't mean that will carry a steady load.
Still nothing...
It's either a bad motherboard or processor. If you have another processor that is supported on that board and you know it works, try it. If it boots return your CPU for a good one.
Unfortunatly, if it doesn't boot with a known-good processor that just proves the board is bad; it doesn't prove your CPU is good. You may have more issues.
Mar 08, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I had a loud fan noise coming from inside my desktop box for a while. One day (& ever since,) when I went to turn the box on, absolutely nothing happened: no fans, no BIOS, no LEDs. I made no config...
This may work however i think by ignoring the sound of the Fan you might have destroyed the cpu and the motherboard.If you can try the processor in another machine you might just have to replace the motherboard only.
Good Luck
Dec 03, 2009 | Intel Motherboard
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Replaced motherboard & pc won't power up
Yours memory card(Ram) may not suitable to your motherboard, read the instruction manual of motherboard, what ram is suitable for your motherboard.
Mar 17, 2009 | ASUS M2N-MX Motherboard
System will not start up. Cpu fan spins once, then nothing.
It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
Power supply Ok.But CPU fans started with seconds It's stop.
sounds to me like your mainboard is bad, i bet if you closely inspect the capacitors around the cpu one or more is bulged out or leaking
Feb 15, 2009 | Asrock P4S61 Motherboard
Power problem
NO POWER Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective. SWITCH PROBLEMS A trick can be done here. Unplug it then spray the switch (Soaked) with warm distilled water with mild soap. then let it dry using a Hair Dryer. Then test! If failed, Replace the switch. If Persists then There is a problem with the Main Board or Power Driver. FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 20, 2007 | Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
