Sounds like you have a chain drive garage door opener and you hear a humming sound when you push the wall console. The motor is running but the chain does not move. You need to replace the gear & sprocket assembly.
If the motor runs and the chain does not then you have stripped the gears and will need to replace them. If the motor runs, the chain moves but the door does not move then the trolley is not attached or needs to be replaced. Thanks BB
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
The drive gear is most likely stripped. It is a white nylon gear just in front of the motor. The parts number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
You should check the gears inside the box, After years , the gears get dry and die, you can by online or from Sears the kit and replace the old gears. I just changed mine...not too difficult :) .
