Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP Officejet 6110
Does anyone know if it is possible to divert an incoming Fax to another fax machine without having to go to BT and pay there massive charges.
  • 181 Answers
This is not available with the 6110. There are printers that have the fax forwarding print option available - from HP I think that the J series OJ's do and most of their higher end products have the feature as well. You can always call them and ask if they will give you a discount to upgrade and make sure that the printer has that option.
I suggest that you say you have a mac computer as well - you will go to Canada and they can help you pick out the best unit for your needs.
Posted on Feb 28, 2008
Unable to scan or fax. I have a HP Officejet 6110 all-in-one printer, copyer, scanner and fax machine. I have never used the scanner and the fax simply stopped working after years of service. The printer...
Thanx for contacting in fixya....
u need to uninstall the printer software and then reinstall if this problem persists again format ur system c driver it is the only sure solution
regards
john symester
Nov 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 won't receive faxon single line phone with dsl
Have you tried to use the machine on a normal phone line? A dsl line shouldn't be any different as far as fax machines are concerned.
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Incoming fax
Can you ask a friend who as a fax machine to fax you something? That would probably do it. If you don't know anyone with a fax machine, do you have a fax machine at work? Send a fax from work to your home fax machine and then check your home machine after work.
Sep 29, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 6110 all-in-one fax/scanner
Not sure what the problem is exactly. You say that your line is good and you successfully sent a fax using the machine but then you said you can't receive or send...apparently using the phone jack you have available for your machine. It should work using any phone jack you have available in your place.
HP.com has a web page that contains a wide variety of fax troubleshooting steps that may help you. Sorry I can't be more specific, but without knowing more about the problem, this is my best suggestion:
Troubleshooting Fax Issues
Post back your results and good luck.
Sep 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
