Question about Saeco V-spresso Espresso Machine
Water leakage- V'spresso machine
Water drips from the steam wand while the coffee is brewing. Also,I'm noticing little pools of water under the coffee maker and don't know exactly where it's coming from but I think from the brew group. I have been cleaning and descaling on a regular basis. HELP!
  • 1 more comment
  • Jeffcpa Mar 26, 2008
    i have the same problem. looks like where the water supply line goes in. maybe it's the seal?
  • Anonymous Mar 19, 2014
    I have a model # SIN 006XN
    Water no long comes out, it still produces steam. I removed and cleaned everything associated with the group shower spout but will no luck and it has been descaled
  • Anonymous Mar 30, 2014
    difficulty in insert brew group
I had the same problem. The water was coming from the front door switch inside top right. I followed the water and turns out the part that needed to be replaced was the steam valve body. #48. http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg and link http://www.shop.partsguru.com/images/1208344975339-771025787.jpeg after I changed it the pool of water under the machine stopped. I hope this helps.
Posted on Mar 10, 2009
  • 2,039 Answers
The pool of water its probably the boiler that leak you can order a seal kit from saeco but itell you the bolt that hold the boiler you have to remove them to change the seal most of time they brake and you got to drill them out big job new seal kit for brew group cheers p.s descaling with vinegar no good descaling solution is the best solution melts calcium vinegar remove in flake and can block maybe thats why our valve leaking cheers
Posted on Jan 29, 2008
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Our Saeco Magix Deluxe (old style) has developed a leak. It happens inside the machine, on the left, and is pretty severe, during coffee making. Sometimes there is just a little coffee ground in the...
Hi
When the machine is done brewing some water is relieved into the drip tray. This is the pressure relief. Some coffee residue is also taken into the drip tray. This is normal. As long as nothing is under the machine your OK.
Oct 23, 2010 | Saeco Magic De Luxe Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Water leaking and coffee dry
Sounds like the boiler is blocked, and machine needs to be descaled. Try this first remove the parnello if your machine has one on the steam wand then using a paperclip clear out the end of the wand, that might be blocked. If it isn't then run the descale to clear out the blockage in the boiler.
Oct 05, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Water dripping of Steam Wand during brew cycle
If water is dripping out of steamwand then the valve assembly is not working properly and needs to be replaced.
Aug 17, 2009 | Saeco Odea-Giro Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Water problem with Saeco Incanto Rondo sClass
Check the nozzle at the end of the steam wand it might be blocked.
Apr 25, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Steam wand not working
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
Saeco V-spresso Espresso Machine Logo
429 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
