Question about Radio Communications
Instructions on how to change channels on TECHNIKA MODEL TA-13
The only channel we seem to be able to use is the same as all the local taxis and delivery people. We have mislaid the instructions can any one help please
  • 4 more comments
  • redsands Jan 30, 2008
    Model is TA-13, and was purchased in Derby, England where we are currently attepting to use it. We are only using it between office and house a distance of 20 feet, but it saves getting wet when it rains
    Thanks I will have to try it when the boss is in and will let you know how we get on much obliged x
    I've followed the instructions but I can't get them to stay on channel 8 they get reverting back to 1 and we get all the interfence again any ideas
  • redsands Jun 02, 2008
    Thanks very much worked a treat
  • Tony Tech Mar 14, 2009
    I've got the same problem with the Technika TA-13 but could not see the solution that was given to you. Please can you help?
  • Louie  Role
    Louie Role May 11, 2010
    Pls, what specific model is your Technika 2-way radio?
    It would also be of help if you can post where (what location) were they bought from and/or where they are being used.
    Looking forward to your reply/post.
Basic Instructions for Technika Model TA-13
On this model there are 7 buttons:
Left to Right these are:
PTT, Push to talk on lh side as screen faces you.
Power/Menu
Scan
Call
Down
Up
Torch Light (on rh side)
Assuming you have used the power button to turn on the radio, the default channel after installing the batteries is 1 or else the last channel to be used.
Press the power/menu button once-briefly, (the current channel will flash for about 10 seconds.) Then use the Up and Down arrows to change channel. Wait for the remaining few seconds and the radio will return to normal operation.
Press the menu button twice, the letter H or L will appear and can be altered by the Up and Down keys to change the power level of the radio. I think this is transmit power which may help you avoid infuriating local taxi companies. Switch back to High power when you're about to go out for the night and need a ride.
Press the menu button three times. This will turn off Squelch control and make a terrible din. Not terribly useful unless you want to pick up a really weak signal (or find out where the taxi driver has taken your neighbour.)
An easy way of finding a channel is to press and hold the Scan button and then the device will rotate through the available channels looking for a signal. When someone transmits, the scan will pause and you can capture it by pressing the PTT button for a second or two. I have found this helpful in pairing my radios with other sets, or picking out channels that work with friend's radios.
Finally, Volume control is really simple, just up and down when not in any other mode.
I had the instructions, which I think included a mention of all available channels I'll scan and post them if ever I find them. hope this part helps though.
Posted on May 31, 2008
  • Steve Richardson
    Steve Richardson Mar 26, 2015
    What is the signal distance please
    Brigadier General:
  • 6,966 Answers
Hi again,
If my understanding is right, the Technika TA-13 is an European PMR446 system. It is the European version of the USA's Family Radio Service (FRS). It is basically designed:
1. for unregulated use of anybody;
2. 8 channels, 500mWatts power, 446MHz operating frequency;
3. Ch8 is normally the general calling channel;
4. Pressing the up/down would change the channel;
5. the display on both radios must be identical (including the small figures) for them to pair up;
6. the "S" normally means Scan channels, the "C" would be clear or cancel, PTT (press to transmit) is on the left side, some versions have the power switch together with the volume control, others have a soft switch at the front.
Sorry about the instruction manual, no luck getting a downloadable copy.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 30, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Jan 31, 2008
    Copy your post changing channels -
    Select channel of your choice,
    press PTT
    should stay there till you change.
    if you power off, it will go back to 8 soon as you power up again,
    if "Scan" is enabled, it will move among the different channels looking for a busy channel (which would be the 1 in your area).
    to disable "Scan", press the "S" button till an icon in the display disappear.
    Cheers
  • Louie  Role
    Sorry....in your version, that should read as -
    "if you power off, it will go back to 1 soon as you power up again,"
  • Louie  Role
    Glad to be of assistance and appreciate the rating.
Hello.
I have been given a pair of Technika two way radios model TA-11 but do not know how to use the buttons and what they do as i do not have a manual.
Posted on Dec 30, 2012
Instructions for Technika model TA-716
http://www.urbooklibrary.com/signup?prod=101&ref=4975711&q=DOC+Technika+TA716+walkie+talkie+pdf&system_controller=rotator&system_action=site&sf=search&sfv=27
Jun 10, 2014 | Radio Communications
How cwn you check a technika top box is receiving instructions from a working remote
UNPLUG RECEIVER FOR 10 MINS THEN TRY AGAIN
WWW.GENUINEREMOTES.CO.UK
Mar 18, 2014 | Televison & Video
Technika tv
You might need to set up the channels in the menus. Try auto scanning the channels. Read you operating manual on setting up the TV.
Oct 23, 2013 | Televison & Video
Used to have a single channel of RAM at 400Mhz 500MB, now replaced with dual channel each 1GB but 333MHz. The PC only detects 500MB in each channel, but has gone into dual channel mode. Is there a bios...
It would seem as if you have got 2x512mb sticks and not 2x1Gb sticks. There is no setting in the BIOS that will change how your system sees your RAM sticks. RAM wasn't made at the 333Mhz speed in 1Gb sticks, it was the expensive end of the market and so was usually only available in the highest speed range for business and industry.
Aug 25, 2013 | Shuttle SN41G2 (811686000198) Barebone
User guide for a technika sc 500172
hi i have a technika tv but when i tune it in i dont know how to lock them in
Dec 28, 2010 | Televison & Video
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
Unable to get channels after Channel 13.
Go into your menu and make sure the tuner is on Cable, then auto-program....Let me know?
Feb 26, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Freeview Box :(
This kind of interference can often be caused by remote pick up from energy saving lamps.
Mar 17, 2008 | Televison & Video
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Radio Communications Logo
5,247 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
