Sony kp61v25 how do i remove the front to replace the screen
  • david mathews
    david mathews Jan 29, 2008
    can you tell me where,,,, my husband is the tech and hes in tje hospital and im doing all i can to make ends meet,,, i have the screen but cant figure out how to get it off, and i have a zenith 20 in with a line across it, its not a loose connection, 20 apex loose connections move it it shuts off ..32 " rca needs a fly back, and a 52 ' jvc that sound like the relay clicking.,, you can her it click 3 time then shuts off,,, ive been in this bussiness for 20 years with him,, but never learned how to repair them,, i can tell you whats wrong but cant do it,, can you kind of guide me through im in a bad situation thanks for any thing you can do
    Genius:
  • 1,554 Answers
That usually has to be done from the rear to get to the mounting screws.
Posted on Jan 29, 2008
  • Karl Whisenand
    Karl Whisenand Jan 29, 2008
    well once you remove the back it will become apparent because you will
    see the screws. it is bulky so I would tape it down around the front
    while you remove the screws so it dosent fall.
    The zenith has a HOT failure but likely the associated caps in the circuit need repalced.
    the apex should be easy to find by tapping on the board with a long plastic tool.
    the flyback is easy to change but you need to make sure the voltage is
    not set to high and that the focus is just right. ( adj on the flyback)
    the JVC may be the low voltage circuit diode 14/15volt just replace it anyway.
    20 years . you kinda sound like my wife thats worked 40 years at a
    typewriter, terminal then computer and still can't turn on the
    computer. At least you know how to surf and willing to try.
    you might see about getting temp help on Craigslist.org you might be surprised who can lend a hand.
I recently moved and the movers broke the front screen of our Sony KDF46E3000 rear projection TV. Is that surface screen available for replacement? Can I do it?
There are two layers in front screen, check both layers are damaged or not.
Part numbers are as follows:
321007211 ... PLATE (E46L), DIFFUSION (KDF-46E3000 ONLY) [front layer] price is $148
321007311 ... PLATE (E46F), DIFFUSION (KDF-46E3000 ONLY) price is $128
Available in Sony Part Store, put part number in search box, hit enter to get result.
Yes, average handy person can replace it, need to take off front screen frame by removing screws at rear sides of tv.
Hope these info will help you.
Thanks.
Jan 03, 2011 | Sony KDF46E3000 46" Television
I have a sony model kdf-e42a10 and I'm trying to replace my screen. However, I have removed all the screws for the top to the bottom, but can't find the bottom screws. Help please.
Remove front speaker grille block assembly as shown in below image then remove screws under that cover to take off front screen as rear screws have already been removed.
Hope this info will help you.
Jul 11, 2010 | Sony Televison & Video
Where is the bulb loacated on kdf42we655
Bulb/ lamp is located under front lower panel that need to be removed. There are two thumb screws on lower corners of front screen if you see tv from rear, remove these screws and take off lower front panel, you will see lamp cover, remove it to see lamp.
Lamp replacement procedure is written in user manual with exploded views. Click Sony Support to download free copy of user manual of KDF-42WE655 for more details.
Jun 21, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen Opening
There are clips that are holding it into place. Take a flathead screwdriver and put it in an area where the front bezel meets the back bezel. Twist the screwdriver around and it should loosen some of the clips, do this in a few places and then enough of the front bezel will be loose to where you can remove the front bezel to the screen.
Once you do that you can remove the screws from the left hand side and the right hand side. Then remove the cable from the back of the LCD and remove the plug from the inverter on the bottom of the screen.
You can now put the new screen in.
Apr 27, 2010 | Sony VAIO NS Series VGN-NS110E/S Notebook
I cant remove the front panel so i can replace the front screen
some pins broke but i had all the screws removed then i was replace the screen , i thought problem fixed but no i have still double colours
63ae33d.pngso as in the picture right side good left side very bad can i trow away the telly or can it be repaired greeting hendriks s
Jan 15, 2010 | Sony KP-44PX3 44" Rear Projection...
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
How remove the Sony Rear Projection TV KDS-R50XBR1
the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
Sony Vaio Laptop VGN-CR240E LCD screen flickering
Mostly it is the problem of the screen's internal mechanism. Something has got loose and moves here n there when moved. If you can, you replace the malfunctioning parts or consult service centre for it.
Aug 10, 2009 | Sony Computers & Internet
How do I remove the screen on a Sony KP-51ws520?
Below are 2 images which helps you to remove front screen (Beznet Assembly)
Good luck.
Jan 09, 2009 | Toshiba 50HDX82 50" Rear Projection...
Replacing front screeen of sony TV projection TV
Hi, assuming you have an expensive sony screen to replace allready, it is fairly hard to do because to take the top off every screw you can see from the back have to come out on top of that the optical engine and circuit boards have to be loosened or removed to get at the last two or three burried deep inside (thanks sony) if you can get that far the rest should be a breeze, just separate the cabinet replace the screen and reasemble
May 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
