Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
My system wont boot.. @ once..need many try to make it boot...
I have the slimline s7520n. my problem is.. system doesnt boot when u press the power at one time.. you will need to keep trying to make it boot... and when finally boot. and your on the windows.. after few minutes or hour.. it will shutdown.. and wont boot on again... im suspecting that theres something wrong with either the system or the video.. can you give me answer or idea.. which will be the problem.. i tried a lot of work on this one.. i re install the windows thinking maybe virus did this..after new window... still do the same... ( the lights(power) is on, system seems running i can hear, hard drive works fine (i tried to the other system) the led lights responds with orange/green color. )
  • 5 more comments
  • jolen323 Jan 29, 2008
    thanks for the responce,, i will try to change the power supply,, i need to order that i guess.. that maybe the problem.. i cant check the video cuz the system doesnt have the agp.. it only has the pci and i dont have the pci video.. the pci express wont fit. im just using the on board video... but it does boot up still but keep shutting down and restart.. so your right.. that maybe the power failure... the system has only 1 memory stick installed(1gig) i will try to get the power replace.. i dont know where to get.. lolz. ... again thanks for the quick responce... my name is lennie
  • nqc2k Feb 08, 2008
    Did you find a fix yet? I have the same exact problem.
  • papabobo Feb 12, 2008
    system won't boot up
  • cvstone Mar 25, 2008
    did you get to fix the proble ,? , because I have the same problem but a specialist tolk me in morelikely to be the mainboard than the power supply. That why I did not replace the power supply. since you have the same problem I would like to know if you fixed an how\\
    Thanks,
    CV
  • badraaos Dec 18, 2008
    When I press on button the screen goes black after few minutes then when I try again to turn it on there are several vertical lines and no booting
  • Anonymous Jan 06, 2009
    hp pavillion slimline s3223w machine wont boot without cd dont have cd
  • daewalkr72 Apr 28, 2009
    i have very similar problem. have tried everything. Looked in bios and cpu fan speed was at 70' c this is in idle with windows not up. Thinking i need faster fan or better heat sinks. If have any ideas would love to hear them?
    Sergeant:
  • 201 Answers
Hey there jolen 323. The issue may be related to your power supply failing, however that would be a pain to replace, so lets consider that video idea. If iyou have a video card, remove it and connect your monitor to the onboard video. If this is effective, replace your video card. Next check your motherboard capacitor to ensure you have not popped any. Normally they are flat on top. When they begin to peak or somtimes burst, there is your problem and may also be related to power supply issues, or poor memory configuration. Also ensure your ram is in good condition and the proper type for your board. If using more than 1 stick, try removing the one furthest from the CPU, and give a test start. the only thing left is to replace Power supply if you are confident in the board. Good Luck!
Posted on Jan 29, 2008
  • 112 Answers
I had the same problem with my computer. The power supply went and was only putting power out to the drives and nothing to the motherboard. I put in a newer and larger power supply and it works alot better.
Posted on Mar 27, 2008
It can be the switch stack or there a lose connection some inside ur machine .try to take your machine to the technician to help you to solve this problem.Good lucky.
Most nyirenda (Mr CPU)
Posted on Mar 26, 2008
My s7520n hp slimline wont boot correctly. When i press the power button it flashes blue and the hp invent screen comes up and freezes, i cant hit f10 or f8 or anything, I waited a day and started it back...
Hello and thank you for your question,
It sounds like there is a corrupt process file in the phone. Please contact your cellular provider so they may fix this setting for you.
Please remember to rate this answer for your ratings help me better serve you and the community of others like you needing help.
Once again thank you for you for using Fixya.com and for all your technological needs please continue to use fixya.com where you will find the answers that Fixya problems.
Sincerely,
Zachery D.
Fixya.com - Guru: zdeuyo
Mar 28, 2011 | Computers & Internet
The computer hangs all the time and will not boot about 40% of the time.
If you have the operating systems disk boot to the disk like you are going to reload operating system ( OS disk example Window XP or Vista Disk) Run though the steps on screen till you get to the point where it asks if you want to load a fresh copy of OS, this will be past the point where you press F8 to continue. Do not load fresh copy of OS. There should be an option to repare you OS. This will fix the OS with out loosing any of you files and stuff on the PC.
Sep 17, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
I would like to reset my HP S7520N PC to original factory settings. How do I do this
reboot your desktop then on the boot up press F11. then follow the instruction displayed.
May 12, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Audio and video driver installer for hp pavilion slimline s752n
You can download the drivers from the HP support site here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=uk&lang=en&product=3199127&
You will need to select your operating system e.g.Winows Vista, Windows XP etc. then select the download that you require.
If you need more help please reply to this message.
Feb 28, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
How can I turn of the HP blue Invent window? My comuter is HP Pavilion 735N
if window Xp installed on ,just press the window button on the keyboard,once wait for feww sec,press letter U,wait for few sec,then press letter U again.
Feb 09, 2010 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Computer wont install windows strange problems ensue.
are you pressing any key to boot from the cd when you get that message??
after windows finishes copying all the installation files during the first stage (dos mode) of the os installation you get a reboot, after the reboot, you should get that message that says press any key to boot from the cd, DON'T PRESS ANY KEY (or you will start again), leave it cd in.. just don't press any key... hopefully the installation process will continue on it's own onto the next stage (graphical mode).
if the computer just goes back to the dos mode without you pressing anything the problem may actually be a real problem and it may require further troubleshooting..
see how that goes with the first suggestion and post back if needed.
good luck
Nov 15, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Change HP Pavilion Slimline s7520n Video Card?
The on-board RadeonXpress 200M graphics is a dog. It offloads a lot of work to your cpu, and shares system memory which ties up the bus and detracts from the memory available to the OS.
The s7520 suffers from thermal problems due to it's size and poor ventilation. It also has a very limted power supply. Therefore, your choices are also limited. If you could score Radeon X600 or X1300 with 128MB for cheap somewhere it would be a worthwhile upgrade. It does need to be PCI (not PCI-E) and half-height (low profile).
Jul 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Need to format the hard drive for HP Pavilion Slimline s7520n, but I don't have the recovery disk. Any ideas on how to do it?
If you own the computer and it is still in warrenty then i would call up HP and explain the situation and have them send you a recovery disk, if it is not in warrenty they may still do it but if it doesnt work your other option is to purchase one or to Pirate one which wouldnt be illegal if you used the product key that came with your computer.
Apr 07, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
283 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
