Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
One card interfering with other connections
I have an adapter (linksys) which always worked properly in my desktop PC along with a laptop all connected to a wireless router (also linksys). Now whenever I startup the desktop not only does it not connect at all it also makes my laptop connection become erratic. When the desktop is shut down the laptop connectin works perfectly. If the laptop is off the desktop still doesn't connect. The desktop randomly sees the wireless connection but is never able to connect to it. The strange thing is that this setup always worked perfectly before and started presenting this problem all of a sudden.
  • WillCollin Feb 08, 2008
    Wireless adapter is not working. I have a broadband router (befw11s4) in one room and the wireless adapter in the other room. The wireless adapter/computer were working together, but then stopped working.
    Problem Solver:
  • 15 Answers
Have you checked to make sure the laptop wireless NIC isn't acting as an AP by mistake? That could explain both desktop and laptop connectivity issues. Just a thought.
Posted on Feb 08, 2008
Yellow Triangle Not Going
First, try shutting down each device, wait 20 seconds and try again. If it was working with this configuration, it should continue to work.
Second, I always suggest that in Device Manager, all network cards, wireless cards, and/or USB hubs have the properties changed to NOT "allow the computer to turn off this device to save power". If the computer turns off the device, some device stay off.. it might be possible to goad them into restarting, but I wouldn't want to do that repeatedly.
Nov 20, 2013 | Dell Computers & Internet
I just set up a wireless network in my house. My config is this Verizon Fios ONT running ethernet Linksys gigabit 8 port switch 150 foot length of cat 6 running to my verizon router from switch 50...
Try disabling the onboard wireless adapter- the two may be conflicting w/ each other. The other thing I can think of is try a system that does NOT have wireless onboard (a desktop for instance)- that way you could see if the issue is indeed the internal connection's broadcast interfering with the usb adapter
Feb 01, 2011 | Cisco Linksys AE1000 High Performance...
I have a new desktop computer that I had to
if your desktop is connected using wireless then it maybe a fault of the adapter.
try conencting your desktop with an ethernet cable directly from the pc to the modem.
also check to see if your pc is under a metal office, or there is wireless telephone near by.
Jan 21, 2010 | Computers & Internet
Dell XP 200 Dimension ethernet port
Hello.
I'd suggest testing with another computer and the same Ethernet cable to your modem to see if the results are the same and to narrow down which component is the problem.
Was it always slow with this setup or did something change.
Is the Linksys adapter connected via USB ? That would be slower than an internal adapter.
Try updating the Linksys adapter software - Device Manager - rightclick - update driver.
Hope these suggestions help.
Dec 23, 2009 | Dell XPS 200 PC Desktop
Ok, my computers internet is not working...Read and help me!
Wireless internet is basically a radio, and radio signals can be interfered with. Simply running a microwave can make your signal go out. Many wireless phones run on the same frequency as your computer, which can mess it up. In any case, wired is always better than wireless.
Nov 08, 2009 | Dell Dimension 4700C PC Desktop
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
HP Laptop does not connect to internet unless directly
Hello dstoller,
You description is very confusing to sort exactly what is or isn't happening.Let me try to sort out what you have:
You have a Laptop
You have a Desktop
Desktop has a printer attached
You have a DSL modem with a wireless router
Laptop via ethernet: Good
Laptop via wireless: Not Good?
Desktop via wireless: Good
Not sure exactly what you are needing help with...
- Vincent
Still not sure what
Nov 22, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
