Question about Samsung CLX 3160fn All-In-One Printer
Printer error bought a new printer and every once in awhile when hiting print the computer shuts down and also shuts computer down when recieving fax help please
You have a power problem, plug the printer in somewhere else, the 3160 is a power hog and has blown many a breaker in my building!
Posted on Jan 31, 2008
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
I bought a Brother MFC 210C Printer - Fax - Copier a few years ago, when it ran out of ink I stopped using it for awhile. I just bought new ink cartridges, took the tabs off and put them in and they are...
Perform reconnection inspections on the printer. Attempt to printer documents. The computer should diagnose the condostion either as missing programs or malalligned printer ink or paper or compartments not closed appropiately.
Jan 29, 2011 | Brother MFC 210C All-In-One InkJet Printer
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
Jul 03, 2009 | Brother MFC-7820N Printer
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jun 18, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Just bought and install fax machine (MFC640cw) I can send faxes but cannot recieve any. Phone rings, it recieves but it does not print.
It was installed on a VOIP connection. The Modem speed was changed to BASIC (9600 bps) which turns the error correction mode (ECM) off. Standard speed -14400 bps which may creat errors.
Steps: Menu/set - Fax - Miscellaneous - Compatibility - BASIC - Menu/set - Stop/Exit
May 21, 2008 | Brother Office Equipment & Supplies
SHUTS DOWN
Did you had a lighting strike the days before?
This is a typical behavior for some short circuit within the main circuit board. Another reason could be a defective part within the main circuit board.
In both ways the main board has to be replaced which costs more than a new mfc!
Dec 04, 2007 | Brother MFC-5440CN All-In-One InkJet...
ERROR 1200
The error 1200 refers to a problem with one or both of your cartridges, and as the printer uses these cartridges to print, it will not be able to print any recieved faxes. To avoid lost data, it blocks all fax usage as a result of recieving this message.
Nov 14, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Samsung CLX 3160fn All-In-One Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
