Question about HP PSC 2210 All-In-One InkJet Printer
Psc 2210 wont run
Keeps giving me the clear carrage jam signal..
  • may55656 Jan 07, 2009
    carriage jam, that is all i get and it won't clear, i move carriage, close cover hit enter and the same thing all over again??
    Novelist:
  • 188 Answers
Please click on the web link given below and perform the steps given in the web page to fix the issue.
Try to move the carriage manually, till it freely moves.
Click on the web link given below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Posted on Mar 24, 2008
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Carrage jam
paper in the printer still open and look
Apr 25, 2012 | HP PSC 1610v All-in-One Printer
PAPER JAM / CARRAGE JAM
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
My printer keeps giving me a paper jam signal but can't find any paper jam and can't reset the printer. Any help?
There are at least 3 places where paper can be jammed in this model. Are you sure you have cleared the jam completely? Here are the instructions for your model:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_006.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=4
Nov 30, 2009 | Brother HL-2040 Laser Printer
Carriage jam
change the carrage block.this error is comin because of faulty carrage cable
Aug 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Cartridge jam won't clear HP 5610v
I had the same problem and just got it to work. go to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00577763&lc=en&dlc=en&cc=us&lang=en&rule=22243&product=441125
go to the section "Moving the carriage" turn on printer and then unplug power. If you still cant move the carrage then remove both toner cartridge and all the trays. Then completely disconnect printer and stand it upright (so paper feed and cartridge tray is on top) Look thru the paper feed area to the left side of toner carrage and you will see a little plastic tab around the bottom back of the carrage. That tab is suppose to be inside a track on the bottom of the carrage. I think that when we put in or took out toner we must have pushed it to hard and that piece jumped out of the track and has "locked" the carrage. I just pushed the carrage up carefully and used a letter opener to move the plastic tab back into place (tab is spring loaded) print working fine now. Hope this solves your problem
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
I keep getting an error (81:01)
The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
Regards
Dave
Dec 10, 2008 | HP DesignJet 500ps InkJet Printer
HP6200 all in one printer "carrige jam clear carrige jam then press ok" There is no carrage jam or any other jam that I can determine. When turned off for an extended time then turned on it...
In order to help you better let me provide you a web-link to a web document which has clear graphical representation of the solution.
Click on the link below to open webpage and follow all the steps given in web document:
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00304007&dlc=en&lc=en&jumpid=reg_R1002_USEN
Thank you.
Nov 28, 2008 | HP Office Equipment & Supplies
HP PSC 2210 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
