Question about Eclipse CD3422 CD Player
Just says Help and INF3
I recently had my car worked on and needed to reinstall the security CD (which I did) to get the stero working and it won't work. It just says HELP and once it gave me a INF3 code. I actually have an Eclipse 5340 and didn't have any problems with it until now. What can I do?
  • 1 more comment
  • RRGIRLVB Jan 29, 2008
    Any idea what the INF3 means or what I am susposed to do if it says HELP?
    It says HELP 99% of the time but the one time I got the different message it was INF3. The message was up there so quickly and then gone that it could have said INFO3 and I just missed the O
    SOrry, I hit the wrong button-what does the ESN security thing entail?
    Brigadier General:
  • 6,966 Answers
Most current models of car stereo units have a systems reset. I was made to understand that your particular model (5340) may do have a tiny reset button.
Alternately, assuming no hardware fault, some versions/models would do a full system restore with the removal of all power connections to the unit for a couple of hours. This should only be done if you have the code or the CD for the security lock.
If both fails, you may want to try and bring your concern to the attention of Fujitsu Ten at www.eclipsediamondservice.com or give them a call (toll free) 1-800-233-2216.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 29, 2008
  • 2 more comments
  • Louie  Role
    Louie Role Jan 29, 2008
    Ooopps, apologies to coolguy008, guess you have posted while I was composing my reply. Cheers all.
  • Louie  Role
    for RRGIRLVB,
    Pls, does the display say "INF3" or "INFO 3"?
  • Louie  Role
    with the indulgence of coolguy008 on his post "The display says- INF3"...
    Some Eclipse models would display INFO # to indicate a problem. INFO 3 indicates disc problem which could mean dirty, unreadable, upsidedown, wrong disc.
    If the "HELP" message appears, the would only indicate that you have tried using the security CD five (5) or more times unsuccessfully.
    If this is an accurate assumption, you need to do the ESN security lock out operation.
  • Louie  Role
    To do an ESN security lock out operation:
    1. Confirm that your unit's serial number is displayed after the "HELP";
    2. Press on the Open/Eject button closing the front panel;
    3. Press on button "6", simultaneously press on the "Screen/Text" button. Hold for 5 seconds;
    4. Display will now be "SEC" followed by scrolling code (6 digits);
    5. Again press the "Screen/Text" button;
    6. Display should show "DISC", if not start all over again;
    7. Pop in your security CD and start process till "OK". If things go as intended/correct, CD will auto eject and unit will now work.
    Following the above steps resets the number of tries before lock out, meaning you can start inserting your security CD again (and you have 5 tries) after which, failure will repeat the "HELP" message.
    Give it a try and good luck again.
    Genius:
  • 3,422 Answers
Well this seems to be kind a tough but i knw a site whr u can register n if u tell thm the same problem they might help u out.
Click here.
Goodluck,
Don't forget to rate me as fixya if this helped u out..
  • Priya darshan Jan 29, 2008
6ya staff
SOURCE:
I disconnected my battery and now I can't get my car stero to work
you may need to reset the security code usually in the owners manual.
Apr 07, 2017 | Cars & Trucks
Car stero won't work
What the model of the stereo??????
Mar 04, 2013 | Car Audio & Video
I replaced the battery on my ford focus, now i need the security code for the stero 6000 cd rds e.o.n. Can anybody help me.
Post the SERIAL NUMBER found on a label on the radio casing
It normally begins with M or V or C  or L
Dec 31, 2009 | 2004 Ford Focus
I have a 2006 lincoln mark lt that has a check engine code VSS
It's possible, was the light out before the audio tec worked on it, if so go back to the guy and ask him if he may have moved a connector or something when working on the stereo. don't go in and accuse him be nice and he will most likely have you fixed in no time.
Jul 25, 2009 | 2006 Lincoln Mark LT
When I turn off my car my stero resets all it's setting
Mike
Here is a owners manal and wire diagram on page 55. You have the yellow wire hooked up wrong need to put to a constant hot not one on a switch.
http://inform3.kenwoodusa.com/manuals/KDCX889.pdf
Good Luck
Dec 18, 2008 | Kenwood KDC-MP628 CD Player
Security code Lockout
I had a similar issue with a head unit in a newer Volkswagen. There was an unlock code burried in the vehicle's owners's manual.
Since your stero is an aftermarket model, I would bet the unlock code is in the manual for the head unit.
Sep 09, 2008 | Kenwood KDC-MPV7019 CD Player
Stero installation
need wiring harness clip and install kit. It is pretty easy after that if you aren't installing amp or subs. what is your question, how to get factory radio out?
Aug 31, 2008 | Pioneer DEH-1600 CD Player
Lexus ls400lexus LS400 nakamichi cd car stero AMP troubleshoot
reset the 3 breakers located near the fuse box by putting a tiny pin into the slots till you hear a click.
Apr 26, 2008 | Car Audio & Video
Eclipse CD3422 CD Player Logo
322 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
