Samsung Blackjack SGH-I607 Smartphone
Problem for Samsung Blackjack SGH-I607 Smartphone
Setup gmail on my samsung i600
By johnny11 on Jan 29, 2008
i have a new samsung i600. I have setup all the gprs functionality to send and receive sms/mms and to acces the internet. The last thing I'm struggling with is the setup to access my gmail account on the mobile
Same Problem
May 05, 2008
-   How do I get onto the internet? I have a wifi at home. I cannot get the phone to log on to the net, inspite of going thru the password, which is not being accepted.
David Tejnani
veda@netvigator.com-   Guest
Apr 26, 2008
-   how can I add the message center number?
-   Guest
Best Solution
posted on Feb 02, 2008
Very Helpful)
mmcardle1980
Rank: Wiz
Rating: 81%, 44 votes
i had the same problem.....i atleast hd to set up an account on my computer first, then i was able to access it from my phone. My setting for att data are as follows go to start, then to settings, next to more at the bottom, then to connections, then to proxy, then to att wap, next make sure you have connects from: wap network then have connects to: the internet and have the type: http.....i had no user name or password in the fields below.
Like i said before these are the options i have set for the att data plan.If your using a wireless router as a accsess point i dont have a configuration for that. Hope this helps
Was this helpful?
Yes
No
Solution #2
posted on Feb 07, 2009
Very Helpful)
cacophonyx
Rank: Guide
Rating: 85%, 2 votes
I can access gmail on my phone; it's fairly straightforward: - unlock the keypad - hit the 'envelope' button at the bottom right to go into 'Messaging' - select the bottom item: "New Acccount" - choose "Other (POP3/IMAP)" from the e-mail provider list and hit Next - Enter your name and email address, then hit Next (leave the "Automatic setup" checkbox ticked; it makes no difference) - hit Next again to skip the automatic configuration - enter your gmail username (with the @gmail.com bit; I like to use the recent:myusername@gmail.com to download only the most recent emails) and password. Leave Domain (if necessary) blank and hit Next - choose server type "POP3", account name "Gmail" and select whatever network (WAP Gateway or Internet) you want to use, depending on how you want to connect - Enter the following - - Incoming Server: pop.googlemail.com - - Require SSL connection should be checked (ticked) - - Outgoing Server: smtp.googlemail.com - - Outgoing server requires authentication should be checked - - Outgoing server configuration: - - - Use different user name for outgoing server (if you've used the recent: username for downloading email) - - - Enter your gmail username@gmail.com - - - Enter your password - - - Leave domain blank and check "save password"  - - - check "Require SSL connection" - - - then click Done - - Select however many day's worth of emails you want to download and click Next - - Select "Never" to connect automatically if you aren't on an unlimited data tariff! - Click Next then Finish.
Hope this works!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung Blackjack SGH-I607
Questions and Unsolved Problems for Samsung Blackjack SGH-I607
Do you recommend Samsung Blackjack SGH-I607 Smartphone?
Answer
Answer
I found this phone and is lock it uses a sim card but when your power on the phone it says phone... (More)
Answer
can i connect samsung m200 for internet on laptop?
Answer
what is the SAMSUNG Omnia Pro GT-B7320 GPRS Settings for MTN Network?
Answer
I cant format my BJII with the up button, since "up" on my phone is broken. what other... (More)
Describe your PDAs problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
