Question about HP LaserJet 3052 All-In-One Printer
HP Laserjet 3052
Getting a scanner error 5. The scanner will light up but it wont move. Any advice would be appreciated.
I am getting scanner error 5 in my hp laserjet 3052, pls giv me the solution for the same
Posted on Feb 17, 2008
CM2320 won't complete startup process and receive scanner error 5
The scanner has only 1 motor and when initializing moves the lamp to the end, where there is a photocell to detect home position. Possibly bad sensor or dirt on tracks which interferes with the movement. Clean the rails with alcohol may correct the problem.
Paul
Jan 04, 2014 | HP Laserjet CM2320nf All-In-One Color...
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
HP-2727mfp scanner error problem
HPM2727mfp - Scanner Error 5 - Scanner Error 8
These errors indicate a problem with the flatbed scanner assembly. The flatbed is no longer able to initialize or find home position. The scanner may move back and forth continually and the light flicker at a high rate of speed. The flatbed scanner will need to be serviced/changed. The part required is CB532-67905
M2727SCANNER
Please contact your local Hewlett Packard Repair Center.
HPPARTNERLOCATOR
Jan 02, 2011 | HP Laserjet M2727nf Multifunction Printer
I have a Microtec ScanMaker 9800XL connected to a Mac OSX 10.5.8 When I scan I get a black screen/no image. I have turned the scanner and computer on and of and have checked the connections. I last used...
did the lamp lights? replace it if not.
if the lamp lights and the comm between pc and scanner is ok and you take black image. then there was a problem on scanner module _light receiver_.
Dec 02, 2010 | Microtek ScanMaker 9800XL Flatbed Scanner
Scanner error 5 turn off then on
Eva, This is a common problem with this machine and more than likely the scanner will need to be replaced. You should try calling HP and see if they will cover it since it is a common problem.
Nov 13, 2008 | HP Laserjet M2727nf Multifunction Printer
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
CS2 CAN'T IMPORT MIRASCAN V342BA
I have a scanner Vuegen scan brisa 620 st
The change computers and operating system I do not support this model
What can I do?
thanks
Jan 28, 2008 | AcerScan 620ST Flatbed Scanner
Scanner error 5
It's a problem with the scanner unable to "see" its home sensor. The home sensor is a black & white film strip stuck onto the flatbed glass, just above where the scanner head homes. The printer needs to "see" the two little black 1mm square bumps in the white area. When the scanner head "homes", as it just disappears under the plastic it should move left and right as it looks at the home strip. If it keeps going and chatters at the right-stop it didn't see the home strip.
This can be caused by dirty mirrors, or lens in the scanner head (clean them);
Low or off color light (replace the bulb or high voltage power board on bottom of scanner head);
Broken, cracked, or loose scanner head ribbon cable (replace or repair);
Dirty or crooked home sensor film strip (I had one of these: the black & white film strip stuck to the flatbed glass was slightly crooked, it doesn't take much!)
Dirty slide bar (clean & oil);
Bad stepper motor, bad scanner PCBA (replace).
Nov 15, 2007 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 3052 All-In-One Printer Logo
866 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
