Question about Car Audio & Video
Sounds not working
I have a lanzar vibe 1800D amp in which i am running 2 x db audio t-rex all wires are correct leading from head unit to amp amp light and fan are working to but no power going to the subs any ideas
thanks ross
  • winslo16 Jan 21, 2009
    I have a boss diablo 3600dd and it is all hooked up correctly, but will not take the music from the radio, i hooked it to and friends and still nothing. Then i hooked the rca cables to the dvd player in my house and BOOM BOOM it worked
    Problem Solver:
  • 7 Answers
You cant forget to connect your remote wire from your deck to the amp, its usually some shade of blue. if its not labeled with some sort of tag or sticker, you can look at a wiring guide that either came with your deck, or on in pdf form online. just buy any kind of wire long enough to reach your amp from your deck. the wire acts as a signal for the amp to start doing its job.
Posted on Mar 17, 2010
    Problem Solver:
  • 10 Answers
Make sure sound signal is coming in the input ports, to test if amp's got reception use a wire and holding it with bare hands touch the input plugs " the middle" it should make a sound like BrRbRBR
Posted on Feb 02, 2008
How can i bridge all 4 channels together on my lanzar vibe 410 car audio amplifier
you cant , you can only bridge 2 channels together and what are you trying to run off the amp?
Jan 30, 2011 | Lanzar Vibe 410 Car Audio Amplifier
Subs Won't work when wired
Based on your post/description, pls try:
1. running the amp's power without the capacitor;
2. manually trigger the amp with the head unit off. Run it an determine if the backfiring still will occur (even with the head unit off);
3. temporarily interchange the left/right wiring;
4. temporarily interchange the + and - speaker wires;
5. run the amp normally trioggered by the headunit but remove the RCA connectors towards the amp.
If your concern has not been corrected or diagnosed which is at fault (wiring, amp, source) after completion of the above procedures, the amp may require an internal look and see.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Lanzar VIBE266 Car Audio Amplifier
I have a Lanzar Vibe 235 amp. the green power light is not coming on, but the red "protect" light is. how do i solve this problem??
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Time to purchase an old school Lanzar Opti Drive. Any of them. The 50 will kill some 12" subs .A thumbs up would be greatly appreciated if this answer is helpful to you. lanzar-vibe-235-amp-green-power-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
Mar 11, 2010 | Lanzar Vibe 235 Car Audio Amplifier
I have a 600watt vibe amp all wires are connected correctly but power light comes on and then goes straight off and repeats this constantly whats wrong??
most amp have a protection feature sounds like somthing is hooked up wrong or u have a short to ground id recheck using a multi meter if all test r good then ur amp needs to be serviced.
Sep 17, 2009 | Lanzar - Vibe: 2 Channel 600W Vibe Series...
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I have a lanzar mxa232 there is a L & R low. I do not have that on my head unit. How do I tie them in?
You would need a Line Output Converter (LOC) to convert the speaker level of the head unit to preamp level.
The amp also has speaker level inputs but the LOC will probably produce better results.
Let me know if you have any other questions.
Aug 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
Annoying thump from two 15" kicker comps powered by a lanzar vibe 266 amp
It sounds like it may be oscillating. This can be caused by a broken ground in the signal line. You need to check the RCA shield on the head unit.You'll need an ohm meter. The following page has more details. If the head unit isn't damaged, the shield ground could be open in the amplifier.
Temporary Shield Repair
Apr 05, 2008 | Lanzar VIBE266 Car Audio Amplifier
Lanzar vibe 230 400 watts amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
Nov 28, 2007 | Lanzar 2H 1000W MOSFET AMP Car Audio...
Car Audio & Video Logo
158 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
