Question about Nokia N95 Cellular Phone
Nokia N95 Wont start up properly
My nokia N95 was working fine and when i went to charge it up it went onto the white Nokia logo screen. Now it wont turn off unless the battery is removed and every time i turn it on it gets as far as the same white and blue logo screen but no further. The screen dims and then lights up again.
Please Help! I use this phone for my business and am lost without it!!!
  • 13 more comments
  • Anonymous Feb 01, 2008
    the mp3 player was on and then I pushed the camera-button, it gave some strange noise "iiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii" and after that rebooted to the white screen with the nokia logo, but it doesn't go any further. I have tried to take the battery off, recharge the battery, take the sim off, nothing works, the same white screen with the nokia logo comes up but nothing else happens. What can be done now ?
  • lawyerppp Feb 22, 2008
  • Kaushikjsr Apr 28, 2008
    I have tried to change my 1gb memory card with a 2gb. Initially it worked ok. I changed the card while the set was on. I switched it off at night, and tried to start in the morning, it didnot. I have connected charger, it is showing charging, but when I push the power on button, It shows only Blue NOKIA logo and then after some time backlight goes off, but phone remains off. Please help. My mail address is kaushik.kumar@sify.com
  • arupu Apr 30, 2008
    i have the same problem when i am trying to switch on the mobile i am getting a wgite screen with nokia in blue and after sometime its getting switch off i cant find any thing else
  • Anonymous Jun 17, 2008
    will not start up
  • killercal Jul 02, 2008
    Hi I have the same problem my N95 8GB turns on as far as the white screen with the Nokia Logo??? please help me calvinhayward@gmail.com
  • Arobenson Jul 22, 2008
    N95 startup problem - Phone just flashing ive tried the *+3+ green button combo but nothing happened- Phone also wont turn off unless u take battery out- Please help-
    \ive taken out the memory card and Pne Sim restarted N95 but no joy
    Common guys there must be a way- Help
    Rgds
    Arobenson
  • Rjk1853 Jul 22, 2008
    i hjust had the new housings placed, and after i got my phone back it wont start up, it just stays at the white logo screen not further
  • oneeyedhairy Aug 10, 2008
    I turned my N95 of to charge, then after the charge had finished I tried turning it on and a white sreen with nokia logo appeared but would not progress from there. when I tried turning the phone off it also did not work until the battery was removed
  • angelyum Sep 19, 2008
    Hi folks,
    I hv a Nokia N95-1, and there seems to be something wrong with it. When I try to load up the phone its just stuck at a screen saying "Nokia," I can't even turn it off without having to remove the battery - it's just unresponsive.
    Any ideas about what's the problem?
  • leja Sep 25, 2008
    my nokia N95 wont work the white screen whould come up with the blue logo i have tried absoulutly everything plz help
  • Anonymous Oct 19, 2008
    dear sir i was up loading my n95 when it shut down and when i turned it on the L.C.D gose to a dark screen nothing more any idea,s I NEED HELP PLEASE
  • molly1972 Dec 10, 2008
    When i turn my n95 on, all i get is a white screen with the nokia logo and i cant get it past there, ive tried a few ideas that have already been offered but still no good... CAn anyone help me please...TY
  • htid22 Dec 11, 2008
    i dropped my n95 and cracked tha screen, after i gt the screen fixed the phone worked fine for a while now when i turn it on it goes to the nokia start up screen then the backlight comes on and the fone seems 2 crash and i have to take the battery out to try and start it again but it never has please help my email is h.t.i.d22@hotmail.com thanks
  • Anonymous Mar 19, 2014
    IT WONT LOAD PASSED THE LG LOGO START UP SCREEN
    WHEN I TURN IT ON ITS LIKE IT GETS FROZEN ON THE LG START UP SCREEN AN WONT LOAD ANY FURTHWR
  • 4 Answers
Hi to all u wot r having the same problem i email nokia last night they got bk to me with this messege and it workis so do this
• Turn the phone off.
• Remove the battery, SIM card and memory card for at least 15 minutes.
• Reassemble and turn the phone on.
Then, monitor the functionality of your phone.
If your phone is not responding, try to recover the device by formatting it manually:
• Press and hold these keys: [3], call and [*].
• Press the power button for 1 second.
• Continue to hold [3], call and [*] until you hear the start-up tone.
and it works i can use my n95 agen now so give it a tri
Posted on Aug 03, 2009
  • jodiestarlat
    jodiestarlat Jul 16, 2013
    their is no #3 or * its a touch screen nokia 710.1 phone color white
Folks, just try switching the N95 on using the little power key / button on the top of the phone.
Posted on Dec 10, 2008
Hi, I had the same problem as the first two with the startup going straight to the white screen with the nokia logo and then it would turn off and restart in a cycle, taking out the battery would not help. This was after having the phone for only 9 days... took it to the Nokia Care Centre, got them to reflash the phone's firmware and it was fixed. I suggest doing the same, it's a firmare corruption that is causing the startup hang. Hope this helps you... ! :)
Posted on Feb 11, 2008
    President:
  • 1,017 Answers
Guest: Try this code with SIM taken out. Soft reset code *#7370#
Posted on Feb 06, 2008
HI,IM HOPING SOME 1 COUD HELP ME,I HAVE A NOKIA N95 AND I DROPPED IT IN WATER,I HAVE REPLACED THE SCREEN AND THE FRONT RIBBON CAMARA HOPPING IT WUD FIX IT,BUT ALL I GET WHEN I TURN ON IS ON THE LEFT OF THE SCREEN U CAN SEE THE NOKIA SIGN AND THE BACK GROUND BUT ITS ALL LINEY IF U CUD UNDERSATN AND THE REST OFF THE SCREEN IS ALL FUZZY BLACK AND WHITE,IM WONDERING IF ANY 1 CAN HELP ME?E-MAIL ME PLZ ON sickboy69r2k@hotmail.com
Posted on Aug 25, 2009
Hello budtoka,
Thanks for solution
Posted on Aug 07, 2010
    Problem Solver:
  • 9 Answers
Find your solution from the list,
Nokia N95
Codes:
Software & Hardware Problems
Find Your Solutions for other Nokia Phones:
Nokia N70
Nokia N73
Nokia 6300
Nokia 6600
All the other Nokia Phones.
Posted on Jul 28, 2010
I solved the problem by removing both the data and SIM-card, placing back the battery and booting it. It did start up normally, and pretty fast by the way, after which I returned the SIM-card. Switch off and on and problem is solved. I didn't place back the datacard yet though..
Posted on May 18, 2008
My camera wont start up, when run it shows a blank white screen and then flicks back to the menu. The barcode reader and all picture uploads using camera works properly.
reset you mobile using this code *#7370# and then press ok it will ask for Security code then type Deafult code 12345
Regards,
MAHAR SHOAIB
http://www.exbiikahani.com
Dec 16, 2010 | Nokia N95 Cellular Phone
When i plug the charger in my Nokia N95, the white (screen is dim) startup screen with the word "Nokia" will appear, then after about 5 seconds the screen will go black and will not charge. This has...
you bought a fake battery or the battery terminal are bad and are having poor contact with the battery.remove the battery and try to clean the three golden panels that come in contact with the battery
Sep 23, 2010 | Nokia N95 Cellular Phone
My N95 kept rebooting itself so i looked around on the net and found that i need to install new firmware. I downloaded nokia software updater and it starting downloading the upgrade. However about 14mins...
You should try to install NOKIA SOFTWARE UPDATE to ur phone to install the new firmware .It is just software problem not any big to worry.You can go to any nokia center to reinstall the firmware and got ur phone A1.
Dec 05, 2009 | Nokia N95 Cellular Phone
I have smashed the screen on my nokia n95,how do i get my numbers onto my pc please help
  1. I solved the problem by removing both the data and SIM-card, placing back the battery and booting it. It did start up normally, and pretty fast by the way, after which I returned the SIM-card. Switch off and on and problem is solved. I didn't place back the datacard yet though
  2. I had the same problem as the first two with the startup going straight to the white screen with the nokia logo and then it would turn off and restart in a cycle, taking out the battery would not help. This was after having the phone for only 9 days... took it to the Nokia Care Centre, got them to reflash the phone's firmware and it was fixed. I suggest doing the same, it's a firmare corruption that is causing the startup hang. Hope this helps you... ! :)
Sep 30, 2009 | Nokia N95 Cellular Phone
Nokia n96 wont start up
do you have a mem card in it ?? found on my n95 the corupt card dint allow it too boot up
Sep 03, 2009 | Nokia N96 Cell Phone
Nokia N96 Corrupt Card
Open the card on your PC and copy all your files to a folder on your desktop. Then go to my computer, right click the memory card and format. When a little window appears just click start.
If your files are deleted then paste them from your desktop back onto your card. This should fix the problem.
Jun 23, 2008 | Nokia N95 Cellular Phone
Nokia 95
Hi
Sounds like maybe the update wasn't as successful as it says it was.
Try the update again, and see if it completes.
I have an N95 and had a few problems with mine, I ended up sending mine back to Nokia for repair.
If your update wont complete, or start, get on the phone to the shop you bought it from because they'll liaise with Nokia. If you bought it elsewhere, get straight onto Nokia yourself here
Mar 30, 2008 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
6,505 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
