Question about HP iPAQ hw6515 Pocket PC
HW6515d Ipaq Sound with TomTom Sat NAv
I have a bizarre problem with my Ipaq whereby with TomTom 6 loaded if you remove the battery cover you can no longer get sound until you hard reset. I have confirmed this by carrying out the same operation without TomTom 6 loaded and the problem doesn't appear. Is it just me? I have the latest official HP ROM loaded.
Cheers
  • Anonymous Feb 12, 2008
    I have the same problem with a H6365. I've removed the SD card with TomTom on and done a hard reset and the sound is working again.
    Any more ideas anyone?
  • Anonymous Mar 10, 2008
    I have looked around a lot for solutions to this and it looks like tomtom6 is simply not supported on this unit...a convenient way for TomTom to just not concern themselves with it. Anyway, I non longer have a 6515, I have traded for an HTC Advantage (Tmobile Ameo).
  • 699 Answers
The IPAQ 6515 will run TomTom 6 quite well. The isssue with th sound disappearing is as per issue as describe by 'Guest' with the RX5710: not compatible BtCoreIf.dll & BtSdkCE30.dll! Google 'BtCoreIf.dll BtSdkCE30.dll tomtom 6' for detailed instructions on how to replace those modules.
Posted on Dec 19, 2009
On my Ipaq RX5710 TomTom altered 2 PDA files on installation (BtCoreIf.dll & BtSdkCE30.dll). Use ActiveSync to browse to \Windows on PDA rename those files to BtCoreIfOld.dll and BtSdkCE30Old.dll. Reboot Pda and sound should work again.
Posted on May 17, 2008
  • 25 Answers
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Posted on Mar 10, 2008
Hp hw6515d no sound loudspeaker
Hi, Antonio--
This appears to be common with the 6515. You will either have to get your headphone jack replaced, or you can try what finally worked for me. Insert and remove your headphone jack as many times as necessary to get the internal connector in the jack to work properly.
It took me about a dozen tries, doing it both fast and slowly.
Jan 13, 2009 | HP iPAQ hw6515 Pocket PC
Sat nav information deleted
I`m sorry no ingles. mi problema es no conecting Microsof
activesync information windows (No se encuentra punto deentrada del procedimiento CeSvcOpenW en la biblioteca de Vinculos dinamicos CEUTL.dll) please solution problem
tenquiu
Mi Naime.Luis Carlos Ibarra Lopez
Maill.- luis_cil59@hotmail.com
Tel.(871)7330269
Aug 23, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
TOMTOM 510 SAT NAV
honestly there is no way to fix battery, as the units are not designed to be opened. if the unit is in waranty contact tomtom for replacement, it not there is not too much that can be done
Apr 25, 2008 | Tomtom GO 510 GPS Receiver
HOW TO FIT BATTERY INTO 510 TOMTOM SAT NAV
i have a tomtomgo700 and need to change battery please help
Apr 18, 2008 | Tomtom GO 510 GPS Receiver
NO SOUND AFTER TOMTOM 6
I had the same issues as mentioned installing TomTom Navigator version 7 onto a HP IPAQ 2415 running Windows Mobile 5. As soon as TomTom was installed the sound stopped working.
I did a Hard Reset to restore the IPAQ which got the sound back. I then downloaded the trial version of WinCE Cab Manager http://www.ocpsoftware.com/products.php?nm=cecabmgr and used this to remove the files Btcoreif.dll and Btsdkce30.dll from the TomTom installation CAB. I saved the cab and then ran this again and it installed perfectly and I still had sound. Hope this offers a solution for anyone still having a problem.
Jan 13, 2008 | HP iPAQ HX2490 Pocket PC
Tomtom300 gps mains charging +
1= My battery is flat, but when i put it on charge in the house it doesnt charge and no green light comes on, on my sat nav why would this be?
Could be your house charger is bad or the power connector on the back of the Tomtom is bad.
2= But when i put it in car charge it works perfect 'Y'?
You are using the "power shoe" to charge the battery. For a test unplug the power cord from the power shoe and hook it to the back of the Tomtom. If this work then the house charger is bad. If this doesn't work then the Tomtom rear power connector is bad
3= If ever i have to change battery how is this done?
You will have to remove the faceplate and disassemble the Tomtom in order to get to the battery. Or you can find a shop that repairs small electronic. Find the battery on Ebay.
Jan 12, 2008 | Tomtom GO 300 GPS Receiver
TomTom Home does not recognise device
Have you created a TomTom account? For each device you own it needs its own e mail address which it links to and you need to be logged in when you plug in your Tomtom.
Oct 22, 2007 | Tomtom ONE GPS Receiver
TomTom ONE
uninstall tomtom home from your computer & restart, then reinstall it from scratch.
This should fix it.
http://www.tomtom.com/support/support.php?ID=2
Jun 20, 2007 | Tomtom One Europe v2 GPS Receiver
HP iPAQ hw6515 Pocket PC Logo
714 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
