Question about Brother MFC 6800 All-In-One Laser Printer
Black line We have had this printer and are very happy with it up until now. There is a black streak going down the paper on the copies. We have cleaned everything on the machine including tearing the machine apart and cleaning both sides of the glass and the rollers, etc. Does anyone have any suggestions to get rid of the black streaks? THANK YOU.
  • BD74 Feb 06, 2008
    That didn't work but thanks anyway.
  • draig-coch Oct 27, 2008
    I get light grey shadowing in the center of my test page, with heavy image loss and vertical streaks on the left and right 2 & 1/2 inches of the page. I have cleaned and recleaned the window and wire as directed to no avail. Getting ready to toss it out and change machines!
  • 11 Answers
Black lines are caused by the scanner failing. Grey or light areas are either the ****-glass under the drum unit or the drum unit itself. If you use aftermarket toner, that could be your problem. Brother is really touchy when it comes to supplies.
Posted on Nov 02, 2008
    Sergeant:
  • 390 Answers
The problem could be the system and not the printer itself. Try turning it off, unplugging and then replugging and switch on try again. Sometimes this can reset errors. Post back if no go lilacgerry xxx
Posted on Feb 06, 2008
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Black line appears on copies fed through automatic top loader
Clean the scan glass, there is lilely a spot or streak on the glass, use a good glass cleaner and soft cloth or paper towel.
Hope this is of some help.
Ed
Apr 21, 2009 | Konica Minolta DiALTA Di200 Copier
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
Black dusty line on my copies
You mentioned when you copy.
If you just have it print with out doig a copy (like have it print an internal report or what ever) does it do the same thing?
If it does (and I'm assuming that this is a laser printer) change the toner cartridge.
If it doesn't, then there is something on the glass area that is causing the streak. Clean the glass with vinegar and water solution (not sopping wet, just damp on the rag) and dry. Test again.
Sep 26, 2008 | Ricoh Office Equipment & Supplies
Brother MFC 6800 All-In-One Laser Printer Logo
352 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
