Question about Sony VAIO VGN-B100BD PC Notebook
What type of RAM this laptop uses so I can upgrade it from 512 MB..I need to know how many pins it uses and that kind of stuff.... Thanks in advance...
  • 201 Answers
The ram you need is 184 pin DDR 333 SDRAM The max you can install is 1.0 GB. Good Luck!
Posted on Jan 29, 2008
What part should i upgrade?
Most easily addressed upgrades would be an additional stick of RAM, increase from 4gb to 8gb, and a GPU with more on board memory 512 mb on GPU is low, just ensure your motherboard is compatible with whatever you choose to upgrade to.
Aug 28, 2017 | Acer Aspire 7741 7741z 7741zg Series...
I have an MSI all-in-one AE1900 with 1GB RAM memory. Theoretically at least I understand it is upgradable to 2GB. I know there is no extra slot to expand but getting mixed information on whether the...
Hi lchangkee...
If you want to upgrade your ram, all you do is remove the ram that is in the computer, and replace it with compatible ram (same number) an example of that would be if your ram was SODIMM 512MB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY, then that is the type of ram you will want to replace it with but more like this.
SODIMM 2GB PC2100 DDR 266 512 MB LAPTOP 200pin MEMORY notice the only thing that changed was the amount from 512 mb to 2 gb. Most memory cards can be removed without any problem...refer to your owners manual as to where the ram is located Please take time to rate me
Aug 31, 2011 | MSI Wind Top AE1900-90SUS - Atom 330 1.6...
What kind of memory does an HPPP2090 has? Does it have capabilities to add more memory and how fast does it run?
Hi - The machine uses SO-DIMM 200 pin DDR SDRAM @ 333 MHz also called PC2700. It came standard with 512 Mb and can be upgraded to two GB. It has two ram slots.
The Laptop was available with Intel Pentium M CPU's at 1.6, 1.7, 1.8 and 2.0 GHz.
Regards and thanks for using Fix Ya
Mar 18, 2011 | HP Computers & Internet
Can i still get ram for that laptop?
Maximum RAM that you can install in your laptop is 512 MB, so if you only have 128 installed in your laptop now YES you can still upgrade your laptop to 512MB.
RAM Specs: InstalledSize: 128.0 MB Maximum RAM: 512 MB Technology: SDRAM - 100.0 MHz FormFactor: SODIMM 144-pin
Feb 11, 2011 | Toshiba Satellite 1800-S253 Notebook
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
Sony VAIO VGN-B100BD PC Notebook Logo
35 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
