Question about Epson LX-300 Matrix Printer
NON STOP OF HEAD
I am having Epson LX 300 printer. when I switched on the printer, the head dosent stop and moving from left to right. is there any solution to it
  • Anonymous Jan 31, 2008
    Same problem at my printer too.Please send me any hint regarding this at atleturoman19@yahoo.com Thanks a lot.
  • 63 Answers
Turn the printer off. Hold down the load/eject,LL/FF, and Pause buttons while you turn the printer on. This will restore the default setting for your printer.
Posted on Feb 07, 2008
Head left side stop.
right click on your epson icon and look for maintance and you should see clean nozles/and any other maintance you can do
Jan 30, 2011 | Epson LX-300 Matrix Printer
Print head moves but doesn't print.
make sure the knb level is set to 0 there is adjustment of head and roller distance .just adjust the lever .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | Epson LX-300 Matrix Printer
LX300 + II Printer Head stack in the middle
it is the problem sensor you open left sensor then folow what condition it then solve i wish you are success
Jul 13, 2009 | Epson LX-300 Matrix Printer
My printer epson dot matrics lx 300 + writes first 2 lines correctly but next lines in italic. what is the solution?
DEAR,
PL CHECK YOUR PRINTER HEAD IS STUCKING OR NOT.
1ST FILL OIL IN PRINTER ROAD (HEAD MOVES ON)
2ND CHECK YOUR PRINTER HEAD BLOCK BUSH IS PROPER SITTING OR NOT.
Feb 26, 2009 | Epson LX-300 Matrix Printer
Epson LX-300+II, the font problem
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Lx-300+ problem
Hi again,
Any development with your Epson LX-300+?
Feb 10, 2008 | Epson LX-300 Matrix Printer
EPSON LX-300
check the flex cable / cable wire attached on cartridge maybe thier a short on the cable.. also check the selection switch..
Jan 04, 2008 | Epson LX-300 Matrix Printer
Epson printer troubleshooting
hi there, you do have a ribbon cable problem, the white strip wire which is connected to the head of the printer. repalce the ribbon head cable and add some cleaning and lubrication on your printer machine. ty
Dec 23, 2007 | Epson LX-300 Matrix Printer
Beeping Epson lx300
The scanner rail (silver round bar running width if printer that head with ribbon runs on) can get dry making head stop, lube with light machine oil.
Canalso be from a faulty ribbon, the ribbon is driven when head moves and if riibon gets stuck head stops toooooo, remove ribbon and ensure you can turn it by hand easierly, replace ribbon...
Nov 11, 2007 | Epson LX-300 Matrix Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
