Question about Mitsubishi VS-50605 50" Rear Projection Television
Televison I have a 50 in mitsubishi television set the timer light blinks on and off for about 5 seconds and when I go to turn the set on the screen never comes on. What do you think is wrong with it?
  • Mitsubishi Master
  • 8,617 Answers
Power supply problem either the horizontal output or regulators are most likely shorted.
Posted on Feb 10, 2008
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Nov 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
My wd-65735 the screen is getting harder to see each time you turn it on, and while it is turned off the timer light is blinking
With the set off the timer light should not blink constantly.
If power is disconnected and then put back it should blink for about 70 seconds and go off (this is set booting up like a computer) and then set should be able to be turned on.
If that like blinks constantly something in the microprocessor is causing it.
This set MAY have the soft reset that was used in a lot of these models:
With Mitsubishi remote turn set on and hit menu, 1, 2, 3, enter.
Mar 19, 2012 | Mitsubishi WD-65735 Television
Turn on the TV and only Timer light is on , no sound & picture
press the menu and input/device buttons both in together on the front of the set and hold for 5 seconds and then see if the set blinks a number of blink pauses and then blinks another number such as 2 blink pause 2 blinks which would be a 22 caode. It then repeats that code.
Jan 21, 2009 | Mitsubishi WS-65809 65" Rear Projection...
TV turns on with sound but blank black screen
This solution from troylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Jan 07, 2009 | Mitsubishi VS-50607 50" Rear Projection...
My Mitsubishi big screen tv will not come back on
Is the light blinking a certain number of blinks then pausing?All mistubishi have a diagnosis feature built in. Try pushing the input and menu buttons on the set and holding them both in for 5 seconds to see if it will blink a diagnosis code.
Feb 10, 2008 | Televison & Video
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi VS-50607
Oct 04, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Need to try self diagnosis, it's here in threads. If not you need live chat!
Oct 01, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50607 Won't Turn On
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
