Question about Motorola Mobility V235 Cellular Phone
Charging prob... I plug my phone to charge the battery, it begins but after a few seconds a message appears that says : "Unable to charge" When I press the power button it sometimes turn on but at the insert pin screen i try to input the pin NO but any button i press lower the volume...
  • 983 Answers
May be the charger is not correct... if it is correct also the pin hole which connect the cell may have became big.... or ur cell charging pin is damaged.... just try with the another charger... u will get rid of it...
if it doesnt works means surely the charging pin in cell is damaged... get replaced with the technician....
Posted on Feb 06, 2008
My iPhone won't turn on
How exactly are you attempting to charge the phone? If the phone is completely dead, you should not use a USB port on a computer or a USB hub to charge it.
Instead, I recommend that you obtain the cube-shaped Apple adapter that plugs into an AC outlet if you don't already have one. It's just a little white cube that plugs into the wall, and it has a USB connector on it. Use an iPhone-to-USB cable to get the phone charging from the wall using that adapter.
Leave the phone connected this way for at least 15 minutes. When the phone gets to a certain minimum level of charge, it should display the battery image on the screen for a few seconds, to let you know it is now beginning to recharge. Note that it may take several minutes before you ever see anything on the screen. Only then will you know it's actually charging. Leave it for a while, and let it charge. If the sound is turned up on the phone, you will also hear a beep when it displays the battery image for the first time.
You can check status periodically by briefly pressing either the round button near the bottom of the phone's face, or the power button on top. It will display the battery image, which will reflect the current state of charge.
Once the phone has at least 25% or more charge on it, you should be able to power it up (while still connected to the charging source). To do so, hold down the power button on the top right edge of the phone until it turns on.
If the phone does not begin to respond after 15 minutes of connection to a known-good charging source, then it has developed a hardware problem and will need to be repaired or replaced.
I can't stress enough that you need to make sure the problem is not the manner in which you are charging it, or the adapter or cable that you are using to charge it. Try multiple cables if you have them, and obtain more than one of the AC adapters to make sure that isn't the problem. If you are using a charging dock of some sort to charge it, that could be the problem as well. You want to eliminate all other possibilities in order to determine for sure that it's the phone.
The only other weird situation that I've seen is if you have a corrupt app that is blanking the screen, making it appear as though the phone is off. To make sure this isn't the problem, press and HOLD the power button on the top right edge of the phone for at least 10 seconds or more. You should see a message that says "slide to power off". Slide the button to power off the phone. Wait until it goes completely black, then wait another 10 seconds. Then press and HOLD the power button on the top right edge of the phone again to restart it.
Cheers,
-=Cameron
Jan 18, 2015 | Apple iPhone4 4G iPhone 4
When charging, the message "check battery" appears
There is nothing wrong if you get this message While You Are Talking, Texting or Surfing the Web. If that is when we receive this message means is that you are using more power from the battery than the charger is supplying at that moment. SO the power/battery monitor in the phone thinks that the battery is bad because the battery is not receiving any of the power that is coming in from the charger BECAUSE you are using the phone while you are charging. So you really don't need to worry about it. If you care about the life of your battery; some experts suggest that the best way it charge is with the phone completely turned off. I know many people believe they can't ever possibly survive life with the phone off. Having said that the next best way to charge is with the phone on but not in use. When you use the phone while you are charging you are putting extra strain on the battery and it's charge control/monitor circuits. Hope this solution is helpful for someone.
Sep 24, 2011 | Pantech Ease P2020 AT&T
Phone was charged yesterday and was working fine last night- This morning there is only a black screen / on/off button does nothing What is prob
Take out the battery and wait for 2 minutes. Re-insert the battery, try booting. If it doesn't work, then check whether the battery is charged or not.Give it for charging, wait a few moments it wont start charging immediately if fully discharged. Kindly comment if the problem persists.
Jul 23, 2011 | Samsung Galaxy S GTI9000 Smartphone
My i phone wont hold is charge i have try lots of charges but is not charging
I had this exact problem too - same as the first two posts anyway.
It seems to be just a software issue and was easily resolved for me with a full power off and reboot. Here is how to do that safely.
Plug in the phone using the wall socket charger, leave it for a few hours to get a charge (i know it doesn't look like its charging). Later, press the on/off button. The battery icon appears with just a thin red line. Let it go back to black. Then press the the on/off button and the menu button simultaneously for about 8 seconds. A red button should appear on the screen with a question asking if you want to power off the phone. Say yes. (I think it was a slide bar, but can't remember now.) Wait a few secs while the phone powers off. Then remove the power plug from the phone. Now reinsert the power plug. After a few (worrying) seconds of nothing, a white Apple logo appears in the middle of the screen, a few more seconds and the iphone main menu appears. No data has been lost, no settings are altered, and best of all, the battery shows a full charge and seems to be back to normal again.
Aug 11, 2010 | Cell Phones
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit www.redmondpie.com for blackrain : www.blackra1n.com
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
Unable to charge my motorola ic502 message is unable to charge. this is second phone in 3 months with same message HELP !!
First take the battery out for a second. then put it back in and put the charger in the hole on the phone. Hold the start button and it should say phone charging. Glad I could Help!
Dec 27, 2009 | Motorola Mobility ic502 Cellular Phone
Battery issues
sound like you need a new battery
Aug 19, 2009 | Motorola Mobility RAZR V3
Problems with phone
it seems like that.but it can be solved.go to the samsung care & ask to restore the phone and update its software.
Dec 24, 2008 | Samsung SGH-J600 Cellular Phone
W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Mar 14, 2008 | Cell Phones
Battery probs
I will suggest u to consult a friend for checking battery or visit motorola care centre
Oct 18, 2007 | Nokia 1100
Motorola Mobility V235 Cellular Phone Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
